Home > Technical > EPB Strange Problem
Paddi
Top man! Well done for having the tenacity to track down that fault.
Can you imagine how much it would have cost if a dealer tried to fix it with their usual tactic of playing 'new part bingo' using your money? You'd probably have a new dashboard and EPB module by now with a £2k bill and no fix.
The correct thing to do would be create a post on 'Faults and Fixes' describing the symptoms and how you fixed it. That's what that section is supposed to be for after all. 2008 MY Java Black TDV8 HSE
Post #409494 Tue Jan 14 2014 3:49pm
mse
Great - its a lesson that some times, faults are faults!! Mike
2014 Facelift Discovery
Post #409500 Tue Jan 14 2014 4:51pm
Agreed! Thumbs Up That section needs to be weeded out and restricted in my opinion. It should be a repository of fixes not the general mish mash we have now. 2012 SDV6 - it's missing a couple of cylinders
Post #409506 Tue Jan 14 2014 5:55pm
DaleKit
Hi Mat,
I have the same problem as you had, do you remember the colour of the wire you had to splice.
Have you any pics?
Dale
Post #452216 Wed Feb 11 2015 12:58pm
TDV8Mat
England 2013 Range Rover Sport Supercharged HSE Santorini Black
Hi Dale,
Can't remember what colour wire it was, but as soon as you get hold of the loom you will see the wire chafed through the plastic coating. N/s/r wheelarch
Post #452232 Wed Feb 11 2015 2:32pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Well done that man ! , I believe that somewhere on here there are a few posts and problems that often mention this plug, and it has been removed and soldered just like you have done with the wire Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #452253 Wed Feb 11 2015 5:19pm
gruodiz
Lithuania
It is green status lamp wire from parking brake module PBM to instrument cluster IPC
+1 for same C1A48-01 solved again Laughing Laughing
Post #506475 Mon Sep 26 2016 8:06pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Excellent, I've bee watching this thread. Funnily, I was thinking of mentioning that connector and associated wiring, as when I was rummaging around the rear of mine, I noticed that the plastic clamp to the chassis had broken, and it was able to move around. I used some tie-wraps to secure it as a temporary measure. Thumbs Up
Post #506745 Fri Sep 30 2016 6:46am
Autodoc
United States 2008 Range Rover Sport 4.4 V8 SE Adriatic Blue
What area are you talking about driver or pass side wheel arch
Post #597027 Thu Mar 26 2020 12:24am
I assume you mean what is n/s/r which is Near Side Rear, which in your case being L/H/D will be the left hand (drivers side) rear fender wheel well.
Post #597028 Thu Mar 26 2020 1:07am
Autodoc
Thanks for the update!! Just never heard nsr before
Post #597029 Thu Mar 26 2020 1:21am
Autodoc
I have the code c1a48 I hope I can find the issue with the wires . The parking brake works and holds and releases, tried clearing the code but it won’t clear . I can hear the actuators working . Is there anything else I should be checking for?
Post #597030 Thu Mar 26 2020 1:33am
