Home > Technical > Heated screen not working
jorn
Belgium 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Hi. I noticed none of my heated screens work. Front/rear.
Checked The fuses and their ok. Also i got current on The connector of the front screen.
Could this be The battery? Or what else? Otherwise car is excellent.
Thx fot your advice.
Post #451105 Tue Feb 03 2015 4:35pm
Thesurveyor
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
My MY12 is in with the dealer for the same issue today, I'll let you know what the verdict is (but my money is on the battery).
Post #451113 Tue Feb 03 2015 5:26pm
jorn
Thx
Post #451114 Tue Feb 03 2015 5:27pm
Try turning up the radio just after starting the engine from cold. Does it go above 20 on the volume or does it say "low power mode"? If it gives the message then that would point to a battery issue. 2012 SDV6 - it's missing a couple of cylinders
Post #451137 Tue Feb 03 2015 8:13pm
jorn
Thank you. I'll try that first thing in the morning.
Post #451138 Tue Feb 03 2015 8:20pm
jorn
tried turning stereo up, but works fine, so i guess i can rule out the battery.
apparently the rear screen does work. only the front, went to a stealer and they did check with their computer but everything was fine. also the fuses and relay seem ok, and current to the connectors, could it be the hole screen thats faulty
Post #451249 Wed Feb 04 2015 4:28pm
Thesurveyor
Update as promised.
Battery replaced and apparently the heated screen now works. This will also hopefully mean that my Satnav does not keep defaulting to Belgium when searching for addresses or postcodes.
Post #451250 Wed Feb 04 2015 4:29pm
jorn
Good, mine is MY12 so i guess it is another system, concerning the satnav i couldn't comment on that as i'm in Belgium Very Happy
Post #451253 Wed Feb 04 2015 4:41pm
