![]() | Home > Technical > Heated screen not working |
| Thesurveyor Member Since: 14 Jan 2015 Location: North West Kent Posts: 8
My MY12 is in with the dealer for the same issue today, I'll let you know what the verdict is (but my money is on the battery). |
| jorn Member Since: 07 Jan 2015 Location: Ypres Posts: 39
Thx |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Try turning up the radio just after starting the engine from cold. Does it go above 20 on the volume or does it say "low power mode"? If it gives the message then that would point to a battery issue. 2012 SDV6 - it's missing a couple of cylinders
Thank you. I'll try that first thing in the morning. |
tried turning stereo up, but works fine, so i guess i can rule out the battery.
Update as promised.
Good, mine is MY12 so i guess it is another system, concerning the satnav i couldn't comment on that as i'm in Belgium |
| All times are GMT |
