![]() | Home > General > New here and to Range Rovers! |
All sounds like complete rubbish. Find a proper specialist. 2008 MY Java Black TDV8 HSE
Before fully replacing the compressor, it may be worth checking if the air dryer is blocked. You can either take it apart and microwave/replace the silica gel inside or just buy a new dryer. http://www.advancedfactors.co.uk/vub504700-air-dryer-5191-p.asp
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Hold on, didnt you say the suspension was working all ok now? Why are you looking to replace it? Drive it till it breaks. Also £2,400 WTF. They are playing on your inexperience with these machines.
May be worth a look: http://www.disco3.co.uk/forum/topic91299.html |
a3lkx Member Since: 10 Jan 2015 Location: liverpool Posts: 19 ![]() ![]() |
Yeah suspension works fine now but he said the compressor is weak, needs lower arms on front, electric handbrake fault and air bag fault along with a service £2400. Air bag fault is the sensors in the seat or seat belt. Parking brake is intermittent signal or module fault, Both of which I can live with. Ill have a look at that disco thread |
The air bag light, not sure on these beasts but can you not unplug the connector and plug it back in? On old cars I had, some kind of static built up and sometimes would throw the airbag light on. Happened in some cars I had if I remember rightly. Plug was usually under passengerseat but not sure on these motors.
Seriously, try this. It's a known issue (and one I suffer from too) - the drivers seatbelt pre-tensioner cable gets a bit stretched/disrupted when the seat is moved. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Cheers guys
Service schedule here: http://www.rrsport.co.uk/gallery/albums/us...0miles.pdf
