![]() | Home > General > New here and to Range Rovers! |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
As Peachy says, your spare was probably nicked at some point and your suspension has a leak or needs a new compressor.
a3lkx Member Since: 10 Jan 2015 Location: liverpool Posts: 19 ![]() ![]() |
Thanks for the reply guys. i have the 4.2 v8 supercharged. I purchased privately |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Im no technical expert and Im new to to these beasts myself. Im not saying this might be the right way to diagnose faulty suspension so try things out for yourself however...
Thanks Joe
There is a site sponsor called Flack - nothing but praise for the guy on here - look him up & send him a pm he lives in Preston & services the surrounding areas - he will - if available should advise if not sort the issues |
Thanks Peachy
In order for the suspension to rise automatically whilst driving I think you have to be driving over 20mph.
Ok just done as Joe advised. Got in started the car, windows down, got out raised and lowered the suspension. I heard the compressor kick in for around 10-15 secs, it was very loud. The car didn't move at all on both sides and same message remains. Spoke to the guy I bought it from and he said he's not had any problems with it all? seemed to be genuine but I could be wrong. I guess its just unlucky?
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
Where abouts in liverpool are you |
crosby |
Ok i use a place called magull 4x4 not to far from you sefton meadows ind est, his name is vince tell him craig sent you |
Just a thought but could it be 2 unlucky leaky bags on the one side rather than compressor? Maybe someone else will let us know.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9115 ![]() ![]() ![]() |
Did it work ok when you bought it? If so, sounds like you're just unlucky and the compressor was tired and has finally given up the ghost.
