Home > General > New here and to Range Rovers!
Page 2 of 3 <123>
a3lkx
2006 Range Rover Sport 4.4 V8 Santorini Black
Thanks again for all your help guys. Yes it was fine when I bought it from what I can gather, I was like a kid in a sweet shop though Smile Only paid attention to the gizmos the other day and seen the message. Just to confirm both sides do not move at all and the passenger side is lower than the drovers side. I tried my code reader but it couldn't read the codes Sad I've only got a bog standard ob2 reader. I will try the guy in maghul and see what he says.
Post #448244 Mon Jan 12 2015 5:43pm
Hopefully it'll be something simple like a leaking reservoir or a valve block that is leaking and causing the system to try to stay level and thus exhausting the reservoir. Both would be relatively cheap (in the scheme of RRS repairs). A new strut or compressor would be a more expensive fix, sadly.
Fingers crossed! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #448267 Mon Jan 12 2015 7:27pm
a3lkx
Thanks guys ill keep you's posted. Ive had a quick look around at new compressors and seen some videos on youtube on how to replace seems straight forward. Cost of pump is £600 which i can live with. Has anyone replaced their compressor before and able to offer any advise?
Post #448274 Mon Jan 12 2015 8:45pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
need to have alook on ebay lot cheaper than £600 Thumbs Up
Post #448278 Mon Jan 12 2015 9:22pm
PEACHY
Agree - £600 is too much Big Cry 16MY Estoril Blue SVR.............
Post #448292 Tue Jan 13 2015 8:21am
a3lkx
Thumbs Up £400 on ebay Very Happy just need to look into 'the job' now. I hope this sorts it out. Do I need to replace the piping etc aswell? the kit on ebay has a relay and pipe work. Also would I need a software update?
Post #448311 Tue Jan 13 2015 12:49pm
Careful - the cheaper ones are often/usually the older model compressor. You need to compare like for like when comparing prices. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #448379 Tue Jan 13 2015 10:46pm
Bodsy
Site Sponsor
The kit with the pipe work and relay, is almost certainly going to np be the newer AMK compressor Thumbs Up that's the one you want.
Easy enough to replace yourself Thumbs Up
You don't always 'need' the software update, it is probably going to work ok but it is definitely recommended to have the proper AMK software update.
About £450 is about right for AMK kit. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #448393 Wed Jan 14 2015 12:09am
a3lkx
Thanks for all the help guys! really glad I joined this forum Smile its been a great insight and am sure I will be back again with another issue Confused I am going to order the part sometime this week ill keep you guys posted.
Thanks again Thumbs Up
Post #448407 Wed Jan 14 2015 11:16am
a3lkx
Hi guys just a quick update.
I have just got back from MT Autos in Liverpool, Great guys and very helpful! I told them my concerns and what I presumed to be a compressor failure. After martin had had a look at the range rover he said he wouldn't like to say what was wrong with it until he had put it into the computer. After plugging it in to his computer the suspension raised to access height and works no problem at all! goes up and down. He has advised that there is a error in communication with something, he did say but I can't remember what exactly and advised I take it to another garage on friday to have his computer sort it out once and for all, as they have the proper system. The engine management light is now on which wasn't on prior as is the airbag light. The suspension raising slowly message has gone but has been replaced with parking brake fault Sad Big Cry Censored Crying or Very sad
Post #448468 Wed Jan 14 2015 5:51pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Interesting update. If I was you, I'd get them to log all the fault codes the diagnostics machine brings up then clear them all. Drive it round for a week and see what faults come back as a lot of them maybe in there from previous years ownership with the car. I'm not Fat. RRS TDV6 HST.
Post #448471 Wed Jan 14 2015 6:33pm
PEACHY
As above - clear the faults then start again - these beasts are very temperamental Big Cry 16MY Estoril Blue SVR.............
Post #448490 Wed Jan 14 2015 8:54pm
a3lkx
The faults where cleared at MT Autos and the suspension released its self somehow and now works? But I have the engine management light on along with the air bag light and a parking brake warning message. I have to take it to another garage on friday with the proper system for them to rest all the parameters and stuff for them to diagnose it properly. Whats the score with a software update reset or an ecu flash? as I think that's what MT Autos did to get the suspension working again, Compressor seems to be fine and works as it should?
Post #448492 Wed Jan 14 2015 9:00pm
FatJoe
Cant help you on the ECU Flash. Never had one done or never needed to. A full reset of codes sorts it for me at my local indie. I'm not Fat. RRS TDV6 HST.
Post #448503 Wed Jan 14 2015 10:16pm
a3lkx
Update:
Just got back from the 4x4 specialists and after they plugged the car into their super computer they have confirmed that the air compressor functions but is weak, they cleared all the faults and took it for a drive. When they returned from the short drive a few faults came back, the electric parking light came back on and the airbag light. The parking warning light is an intimating sensor or module fault and the air bag light is a connection on the seat/seatbelt. Other than that the car is fine he said and worth every penny I paid for it which was reassuring as I was wondering what the hell I had bought. So the electric hand brake light I can live with and the seat connect also, but what would peoples thoughts be on having the compressor replaced like for like as advised by the specialists and not the new pump upgrade. He said that hitachi had reviewed the replacement kit and revamped their new hitachi pump which is just as good if not better. The plus side is that you don't need to replace all the pipes and do the software etc and should make my life a little easier if I decide to do the job myself. I asked for a quote on the parking brake and seat belt fix and I nearly fell to the floor! Parking brake module supply and fit was £800 and the airbag issue would be around £300 but he needs to confirm the actual issue before hand. Whilst I was there he said my lower arm bushes where worn and would need replacing soon at a cost of £750. All issues fixed and a service £2400!
Post #448637 Fri Jan 16 2015 2:43pm
Page 2 of 3 <123>
