Home > Faults & Fixes > Need help
Wayneclarke
Need help
I've opened my bonnet but now the alarm goes off when I try and lock the car also it's saying the bonnet is open
Post #446496 Sat Dec 27 2014 6:49pm
Have a look here: http://www.rrsport.co.uk/forum/topic20468....ood+switch 2012 SDV6 - it's missing a couple of cylinders
Post #446497 Sat Dec 27 2014 6:54pm
Andi
I had this problem recently, sprayed the alarm switch all over with WD40, and that sorted it!
Post #446498 Sat Dec 27 2014 6:56pm
Disco_Mikey
My switch failed, so was shorted out with a split pin. Then my split pin started playing up, so the connector was cut off, and the wires soldered together Thumbs Up
Post #446501 Sat Dec 27 2014 7:07pm
Wayneclarke
I unplugged the switch and back in and it seems to have worked will have a better look in the morning
Post #446504 Sat Dec 27 2014 7:29pm
rudadu
Scotland
I had the same problem. Cleaning the gunk from the switch helped for a wee while but problem eventually returned. I disconnected switch and did similar bypass as described by Disco_Mikey with a small piece of wire until I bought a new switch. £10 or £12 I think it was. The switch itself is really easy to replace in a few minutes. 2016 L494 SDV6 HSE Dynamic Carpathian Grey
Post #446613 Sun Dec 28 2014 10:32pm
Wayneclarke
I've ordered the new switch anyway so will change it but thanks coral the info guys
Post #446624 Mon Dec 29 2014 4:39am
