Home > General > extreme wobble when braking ##please help~~~ |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
More questions than answers but with a reason
Thu Sep 04 2014 9:42pm |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 |
your tiers may have gone out of shape try swapping the back with the front ones |
Thu Sep 04 2014 9:44pm |
m40cca Member Since: 04 Sep 2014 Location: leeds Posts: 89 |
Mark I've swapped the wheels from front to back |
Thu Sep 04 2014 9:48pm |
Simple1 - the wobble/vibration isn't there at low speeds but I don't get anything through the peddle even at high speeds
Thu Sep 04 2014 9:51pm |
well it looks like the only thing you've not touched is the steering but i wouldn't know how to test it sorry |
I hope the discs were genuine!!! |
Thu Sep 04 2014 9:52pm |
I was thinking this mark maybe the steering dampner and bushes next |
Thu Sep 04 2014 9:57pm |
Dial test indicator. Measures deformity in discs. It's not going to be steering rack or mountings, would do it all the time, hence asking about speed and pedal bounce. No bounce rules out discs, so as you have replaced bushes and ball joints you need to start looking at drive items. If you haven't replaced the arm bushes start there first as moving arms will cause the geometry to change when loaded under braking 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Sep 04 2014 11:02pm |
Thanks simple1 these bushes you talk about are these the ones in the lower and upper front arms the ones which the ball hints are fixed to? Thanks again |
Thu Sep 04 2014 11:06pm |
Yes, they mount the arms to chassis 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Sep 05 2014 6:56am |
Thanks simple1 I'll give these a try now then
Fri Sep 05 2014 9:04am |
Easy way to check these is to get someone to sit in car with foot brake applied and try and pull away while watching wheels. If they move back in arch bushes are shagged. In extreme cases, wheels will have back and forth play (front to back) while jacked up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Sep 05 2014 9:20am |
Simple1 I took your advice and changed all lower arm bushes and still there!!!!
Sat Sep 13 2014 3:39pm |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
If you have checked run out on the discs as Simple1 has said and it's within tolerances then I would be looking at the calipers. The other thing it could be is brake transfer but if you have put on new discs and bedded them in it is unlikely.
Sat Sep 13 2014 3:55pm |
