Home > General > extreme wobble when braking ##please help~~~
Page 4 of 4 <1234
Bodsy
Site Sponsor
The braking power further out on the disk, means the disks do slow down more. Sure, not to the big 4/6pot setup, but it does make a measureable difference in reality. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #436831 Wed Sep 17 2014 2:47pm
m40cca
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Fitted brand new genuine discs and pads today so need to bed them in and I'll let you know the outcome guys!
Post #436992 Thu Sep 18 2014 7:13pm
Bodsy
Site Sponsor
Did you change your caliper carrier as well? If it's still sticking, then you're likely to end up in the same position..... Bodsys Brake Bible
See it HERE
Post #437009 Thu Sep 18 2014 8:59pm
m40cca
I took off the carrier cleaned it all up greased each pin so they were nice and free like you said made sure everything was clean before I put it all back together
Post #437010 Thu Sep 18 2014 9:01pm
Bodsy
Site Sponsor
Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #437011 Thu Sep 18 2014 9:05pm
m40cca
I'll let u know the outcome bodsy once I've bedded these new discs and pads in
Thanks again for your help and advice
Post #437012 Thu Sep 18 2014 9:07pm
m40cca
Drove to hull this morning for a meeting everything feels good no wobble vibration nothing haven't been really jumping on the brakes as I want to bed them in properly but at the moment all feels good
Must have been various things like warped discs the caliper stuck and maybe everything just needed a good clean
Thanks boys for your suggestions and help Thumbs Up Bow down
Post #437043 Fri Sep 19 2014 9:00am
m40cca
Car drives spot on now brakes how it should no wobble at 80mph
So we r all good
Post #437066 Fri Sep 19 2014 3:18pm
Page 4 of 4 <1234
