![]() | Home > General > 6 head light bulbs !? |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
That would be the cornering lamp which can't be switched on manually. Only comes on automatically when you are turning (pretty sure you need to be indicating as well) at low-ish speeds. You'll notice it is pointing at an angle, to light up the corner you are turning into. |
| hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63
cheers I guess the car has to be moving , when not moving indicator on and in drive the bulbs do not come on |
Yes, the car needs to be moving but at a low speed so that the cornering light doesn't come on when you are changing lanes on a motorway for example. Take a look at the owner's handbook if you need more details. |
thank you |
| scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 |
you dont need to have the indicator on btw.. |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924
Surely it does? How does it know which one to put on? 2026 P460e Autobiography on order
May be it detects steering wheel angle. I never take a turn without indicating so to me cornering lamps only seem to come on after indicating. Will try without indicator to confirm. Btw cornering lamps should not be confused with adaptive headlamps which are not fitted to all cars. Adaptive ones actually rotate the main headlight beam based on steering wheel position and work at high speeds too. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9155
Where adaptive lights are fitted, the cornering lights activate without a turn signal if the vehicle's speed is in the correct range. In the adaptive system, the "cornering lights" are called "static bending lamps" - they're the same bulbs in the same location but they are used differently.
| designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338
I love them, all but their horrible yellow colour, what bulb do I need to buy to make them match the main beam's 5500k temp? |
| Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179
anyone got a pic of these lights ? perhaps a stupid question, but, how do you tell if you have them |
Because they come on as you indicate and turn, just look at the ground as you next turn at night. 2026 P460e Autobiography on order
The only bulb pointing slightly outwards instead of straight ahead. This one:
Ah , yep got them, horrible yellowish bulb, so as designboy said, what bulb and how to replace |
| All times are GMT |
