Home > General > 6 head light bulbs !?
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
tell me if I am being stupid but I have in my head light a side light bulb indicator low beam high beam and another bulb that does not light up what ever I have on high beam etc help please
Post #434857 Mon Sep 01 2014 4:21pm
fkarim
That would be the cornering lamp which can't be switched on manually. Only comes on automatically when you are turning (pretty sure you need to be indicating as well) at low-ish speeds. You'll notice it is pointing at an angle, to light up the corner you are turning into.
Post #434859 Mon Sep 01 2014 4:32pm
hard2beat2014
cheers I guess the car has to be moving , when not moving indicator on and in drive the bulbs do not come on
Post #434861 Mon Sep 01 2014 4:44pm
fkarim
Yes, the car needs to be moving but at a low speed so that the cornering light doesn't come on when you are changing lanes on a motorway for example. Take a look at the owner's handbook if you need more details.
Post #434862 Mon Sep 01 2014 4:48pm
hard2beat2014
thank you
Post #434863 Mon Sep 01 2014 4:50pm
scarey
you dont need to have the indicator on btw..
Post #434929 Tue Sep 02 2014 9:10am
jimbg
Surely it does? How does it know which one to put on? 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #434930 Tue Sep 02 2014 9:11am
fkarim
May be it detects steering wheel angle. I never take a turn without indicating so to me cornering lamps only seem to come on after indicating. Will try without indicator to confirm. Btw cornering lamps should not be confused with adaptive headlamps which are not fitted to all cars. Adaptive ones actually rotate the main headlight beam based on steering wheel position and work at high speeds too.
Post #434932 Tue Sep 02 2014 9:25am
jimbg
True, I always indicate!!
But it is the indicator that makes it work. 2026 P460e Autobiography on order
2006 HSE
Post #434937 Tue Sep 02 2014 10:12am
Where adaptive lights are fitted, the cornering lights activate without a turn signal if the vehicle's speed is in the correct range. In the adaptive system, the "cornering lights" are called "static bending lamps" - they're the same bulbs in the same location but they are used differently.
The adaptive system still does the "corner light with indicator switch" thing too, by the way. 2012 SDV6 - it's missing a couple of cylinders
Post #434945 Tue Sep 02 2014 11:48am
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I love them, all but their horrible yellow colour, what bulb do I need to buy to make them match the main beam's 5500k temp?
Post #435833 Tue Sep 09 2014 9:06pm
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
anyone got a pic of these lights ? perhaps a stupid question, but, how do you tell if you have them
Post #435913 Wed Sep 10 2014 5:48pm
jimbg
Because they come on as you indicate and turn, just look at the ground as you next turn at night. 2026 P460e Autobiography on order
2006 HSE
Post #435914 Wed Sep 10 2014 5:54pm
fkarim
The only bulb pointing slightly outwards instead of straight ahead. This one:
Post #435923 Wed Sep 10 2014 6:29pm
Mister B
Ah , yep got them, horrible yellowish bulb, so as designboy said, what bulb and how to replace
Post #435928 Wed Sep 10 2014 7:00pm
