Home > Technical > Rear wheel bearings
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Rear wheel bearings
Advise needed. If a wheel bearing failed would there be a continuous noise? My issue is It sounds like a rubbing sound as the wheel rotates but gets louder at one spot only. If I turn right it disappears. I've just changed all my brakes discs and pads including parking brake shoes. Misalignment? Thanks
Post #427121 Fri Jun 13 2014 9:12pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Jack up the wheel and check for any play by rocking top and bottom. Should not move at all. Check that the inside of the tyre has no bumps or flaps of rubber sticking out and check the brake back plate hasn't been bent towards disc. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #427126 Fri Jun 13 2014 10:20pm
RossM
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Did you manage to resolve this as I'm having the same problem. I'm just researching before I pop outside and start investigating. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #427879 Sat Jun 21 2014 3:24pm
SCdavies
It turned out that I needed to bed in my new parking shoes.
Post #427880 Sat Jun 21 2014 4:34pm
martyn05
how do you bed them in ?? Just had new ones fitted to mine. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427917 Sat Jun 21 2014 11:14pm
SCdavies
In the search option above type in parking brake bedding. You should get full instructions on how to.
Post #427947 Sun Jun 22 2014 10:18am
There is a LR procedure for bedding in the parking shoes.
Quote:
Parking Brake and Actuation - Parking Brake Shoes Bedding-In
General Procedures
• NOTE: This procedure must be carried out if, new parking brake shoes are fitted, new rear brake discs are fitted or if the vehicle
has been mud wading (not water) for more than 50 miles.
1. Carry out the parking brake shoe bedding-in procedure.
2. NOTE: The electronic parking brake 'Service Bedding-in Procedure
mode' will be active for the remainder of the igntion cycle, or until
the vehicle speed exceeds 31 mph (50 kph). If the procedure needs
to be re-entered, the entry actions must be repeated.
To enter 'Service Bedding-in Procedure' mode.
Start and run the engine.
Apply the footbrake 3 times within 10 seconds and hold
applied after the 3rd application.
Apply the electronic parking brake switch 4 times, followed by
3 release applicationswithin 10 seconds.
3. Once the Service Bedding-in procedure mode has been entered,
the electronic parking brake linings can be bedded-in by
conducting 10 repeated stops from 30 - 35 kph (19 - 22 mph),
followed by a 500 metre (547 yard) interval between each stop to
allow the brakes to cool, using the electronic parking brake control
switch.
The electronic parking brake brake force will be increased up
to the dynamic maximum so long as the switch is held in the
applied position.
If the switch is released toeither the NEUTRAL or OFF
positions, the electronic parking brake will be released.
The electronic parking brake MUST be allowed to cool
between applications, either by driving at 19 mph (30 kph)
for 500 metres (547 yards) or remaining stationary for 1
minute between each application.
 2012 SDV6 - it's missing a couple of cylinders
Post #427948 Sun Jun 22 2014 10:22am
