![]() | Home > Technical > Rear wheel bearings |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Jack up the wheel and check for any play by rocking top and bottom. Should not move at all. Check that the inside of the tyre has no bumps or flaps of rubber sticking out and check the brake back plate hasn't been bent towards disc. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
Did you manage to resolve this as I'm having the same problem. I'm just researching before I pop outside and start investigating. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
It turned out that I needed to bed in my new parking shoes. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
how do you bed them in ?? Just had new ones fitted to mine. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
In the search option above type in parking brake bedding. You should get full instructions on how to. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9114 ![]() ![]() ![]() |
There is a LR procedure for bedding in the parking shoes.
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
