![]() | Home > Technical > Towing and warning lights |
| Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662
Did you have genuine Land Rover or aftermarket towing electrics fitted? Like this site? Buy some RRSPORT goodies to show your support! |
| Danté Member Since: 08 Oct 2013 Location: Dordogne Posts: 3
The electrics are genuine land rover parts (the trailer indicator light works) and the tow bar is Thule. When I towed with 1 horse there was no problem, 2 horses seem to be the problem. No problems in everyday running around. I do wonder if the towbar is slightly low as there are a lot of different height adjustments on the actual tow bar and with the heavier load it pushes the RR down too much |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
It does sound like the rear suspension is carrying too much load. 2012 SDV6 - it's missing a couple of cylinders
The towbar is set at 400mm at the moment, I am going to get it changed to 450mm and see how that works .. Anyone know what is the ideal height for a heavy trailer is? Thank you. |
| All times are GMT |
