![]() | Home > Technical > Transmission fault suspension lowering reduced power |
Louiscypher Member Since: 29 Sep 2012 Location: Northampton Posts: 42 ![]() ![]() |
Ive been having the same problem for a while now and the local dealer just cleared the faults saying 'no fault found' - only for it to happen again several times.
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
this happens to me too. The suspension error light and engine management light comes on, with the 'reduced engine performance' message. Still drives OK though. Twice, on start up it's gone into a sort of limp mode - without the limp mode message though. This is what happens.
I've 4 (yes 4!) days left on my warranty so it's in the garage being looked at today - I told them not to just simply clear the faults and hope it doesn't happen again! '10 RRS 5.0 SC
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9084 ![]() ![]() ![]() |
Sounds like you need to renew your warranty too. 2012 SDV6 - it's missing a couple of cylinders
damned expensive but I guess it's cheap when compared to the amount of money to keep these things running. '10 RRS 5.0 SC
Just got a call - high pressure fuel pump needs replacing.... And I've decided to extend the Warranty... '10 RRS 5.0 SC
Does your car fall within the recalls
Just outside: SALLSAA139A193806 '10 RRS 5.0 SC
Interesting to hear that they think it's the HP fuel pump. Hopefully that will solve your issue and we will have another piece in the "what's gone wrong this time" puzzle that is RRS ownership!
Ay idea on the cost of the Fuel Pump - they've quoted around £1400 fitted. '10 RRS 5.0 SC
Various warning lights come, suspension lowers, loss of power. Cycle the ignition and everything ok ?? Get the steering angle senser checked and recalibrated.
Well, since the fuel pump's been changed it's been ok but it's early days and the fingers remain firmly crossed.... '10 RRS 5.0 SC
The fault I was thinking of was on overfinchred's car.. 2008 G4 RRSport TDV8 current
Well, went for a long run today (Motorway speeds(ish)) and the car performed faultlessly so (once again) hopefully replacing the High Pressure Fuel Pump has fixed it! '10 RRS 5.0 SC
