Home > Technical > Transmission fault suspension lowering reduced power
overfinchred
As the title says all that appeared on the dash
Just overtaken and then this warning appeared and yes I lost power which was not funny as in outside lane
Happened twice more this weekend
Clears when restarted
Any ideas anyone “One good thing about music, when it hits you, you feel no pain.”
Current RRS Overfinch TDV8, Nissan Skyline R34 GTT, 1958 VW Splitscreen camper, 1961 VW Splitscreen Double cab pickup( now gone), Fiat 500
Gone -BMW X5 and X6, Jaguar XF, Chrysler 300c, Nissan Figaro, Nisan 350z,BMW 3 series, Merc 220d, various Fords, Mini Cooper, 3 old shape mini's, Ford Capri
Post #395094 Sun Sep 15 2013 7:27pm
Louiscypher
2009 Range Rover Sport TDV6 HSE Bourneville
Ive been having the same problem for a while now and the local dealer just cleared the faults saying 'no fault found' - only for it to happen again several times.
Using my IIDTOOL I see:
E023-ENGINE
torque information
and
117D-UNKNOWN '10 RRS 5.0 SC
'13 Cayman S
Post #395151 Mon Sep 16 2013 11:23am
B3EEE
Wales 2005 Range Rover Sport Supercharged Vesuvius Orange
this happens to me too. The suspension error light and engine management light comes on, with the 'reduced engine performance' message. Still drives OK though. Twice, on start up it's gone into a sort of limp mode - without the limp mode message though. This is what happens.
I start the engine. It automatically revs to 2500RPM, it slowly reduces to idle, very lumpy. I touch the gas and it shoots back up to 2000RPM then slowly increases to 2500RPM on its own ! No gas ! Then takes a minute to rest at idle. This happens 2-3 times and then seams to be OK once the engine has warmed up. No problem then whilst driving, but sure I have a miss-fire somewhere so having that checked out.
The suspension error light comes on at totally random times with no common reason for it and no visible affect on driving.
I never had a fraction of these sort of problems with my previous FFRR  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Prefer RR Vouge S/C but they don't do Orange !
Post #395246 Tue Sep 17 2013 9:16am
Louiscypher
I've 4 (yes 4!) days left on my warranty so it's in the garage being looked at today - I told them not to just simply clear the faults and hope it doesn't happen again! '10 RRS 5.0 SC
'13 Cayman S
Post #395248 Tue Sep 17 2013 9:18am
Sounds like you need to renew your warranty too. 2012 SDV6 - it's missing a couple of cylinders
Post #395253 Tue Sep 17 2013 10:01am
Louiscypher
damned expensive but I guess it's cheap when compared to the amount of money to keep these things running. '10 RRS 5.0 SC
'13 Cayman S
Post #395254 Tue Sep 17 2013 10:22am
Louiscypher
Just got a call - high pressure fuel pump needs replacing.... And I've decided to extend the Warranty... '10 RRS 5.0 SC
'13 Cayman S
Post #395287 Tue Sep 17 2013 3:59pm
SRE
Spain
Does your car fall within the recalls
Vin Numbers
SALLAAA147A412306 to SALLAAA149A512711
SALLSAA147A983192 to SALLSAA649A215295
Recall Numbers
P008 http://tinyurl.com/83s2xgr
P021 http://tinyurl.com/6u89gfw In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #395289 Tue Sep 17 2013 4:10pm
Louiscypher
Just outside: SALLSAA139A193806 '10 RRS 5.0 SC
'13 Cayman S
Post #395290 Tue Sep 17 2013 4:12pm
Interesting to hear that they think it's the HP fuel pump. Hopefully that will solve your issue and we will have another piece in the "what's gone wrong this time" puzzle that is RRS ownership!
Good call on the warranty. LR's is quite pricey but it covers quite a lot, especially if you qualify for the Approved version rather than the Select version which I'm now limited to. 2012 SDV6 - it's missing a couple of cylinders
Post #395291 Tue Sep 17 2013 4:13pm
Louiscypher
Ay idea on the cost of the Fuel Pump - they've quoted around £1400 fitted. '10 RRS 5.0 SC
'13 Cayman S
Post #395368 Wed Sep 18 2013 12:51pm
Camelrock
Various warning lights come, suspension lowers, loss of power. Cycle the ignition and everything ok ?? Get the steering angle senser checked and recalibrated.
There are a few threads on the D3 web site with these symtoms.... 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #396190 Wed Sep 25 2013 9:37pm
Louiscypher
Well, since the fuel pump's been changed it's been ok but it's early days and the fingers remain firmly crossed.... '10 RRS 5.0 SC
'13 Cayman S
Post #396200 Thu Sep 26 2013 6:02am
Camelrock
The fault I was thinking of was on overfinchred's car.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #396211 Thu Sep 26 2013 8:41am
Louiscypher
Well, went for a long run today (Motorway speeds(ish)) and the car performed faultlessly so (once again) hopefully replacing the High Pressure Fuel Pump has fixed it! '10 RRS 5.0 SC
'13 Cayman S
Post #397202 Fri Oct 04 2013 8:18pm
