Home > Technical > Transmission fault suspension lowering reduced power |
Louiscypher Member Since: 29 Sep 2012 Location: Northampton Posts: 42 |
Ive been having the same problem for a while now and the local dealer just cleared the faults saying 'no fault found' - only for it to happen again several times.
Mon Sep 16 2013 12:23pm |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
this happens to me too. The suspension error light and engine management light comes on, with the 'reduced engine performance' message. Still drives OK though. Twice, on start up it's gone into a sort of limp mode - without the limp mode message though. This is what happens.
Tue Sep 17 2013 10:16am |
I've 4 (yes 4!) days left on my warranty so it's in the garage being looked at today - I told them not to just simply clear the faults and hope it doesn't happen again! '10 RRS 5.0 SC
Tue Sep 17 2013 10:18am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8872 |
Sounds like you need to renew your warranty too. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 17 2013 11:01am |
damned expensive but I guess it's cheap when compared to the amount of money to keep these things running. '10 RRS 5.0 SC
Tue Sep 17 2013 11:22am |
Just got a call - high pressure fuel pump needs replacing.... And I've decided to extend the Warranty... '10 RRS 5.0 SC
Tue Sep 17 2013 4:59pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Does your car fall within the recalls
Tue Sep 17 2013 5:10pm |
Just outside: SALLSAA139A193806 '10 RRS 5.0 SC
Tue Sep 17 2013 5:12pm |
Interesting to hear that they think it's the HP fuel pump. Hopefully that will solve your issue and we will have another piece in the "what's gone wrong this time" puzzle that is RRS ownership!
Tue Sep 17 2013 5:13pm |
Ay idea on the cost of the Fuel Pump - they've quoted around £1400 fitted. '10 RRS 5.0 SC
Wed Sep 18 2013 1:51pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Various warning lights come, suspension lowers, loss of power. Cycle the ignition and everything ok ?? Get the steering angle senser checked and recalibrated.
Wed Sep 25 2013 10:37pm |
Well, since the fuel pump's been changed it's been ok but it's early days and the fingers remain firmly crossed.... '10 RRS 5.0 SC
Thu Sep 26 2013 7:02am |
The fault I was thinking of was on overfinchred's car.. 2008 G4 RRSport TDV8 current
Thu Sep 26 2013 9:41am |
Well, went for a long run today (Motorway speeds(ish)) and the car performed faultlessly so (once again) hopefully replacing the High Pressure Fuel Pump has fixed it! '10 RRS 5.0 SC
Fri Oct 04 2013 9:18pm |
