Maxarn58
Hello Lingo.
First, welcome to the forum.
The loud buzzing sound is most likely the aircompressor for the suspension.
Itīs located just under the rear door on the left hand side of the car.
A common fault is that the workshop lift the car, not in the intended hole in the subframe of the car,
but put the jack in the drainhole under the compressor, and lifts.
Then the aluminium frame that holds the compressor brakes, and the compressor is "loose"
in itīs compartment, that gives a very loud buzzing sound.
The compressor works, but itīs annoying.
When You alter the suspension from normal to low or to high,You dont get a
message that says that it is done, just a Little "Icon" in the central info window,
that shows your setting.
To see when it is ready, You have to look at the side of the switch, when the Little light stops blinking, it is done.
Hope that this was of any help.
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Thu Sep 12 2013 6:09pm |
