Home > Technical > loud Buzzing Noise when raising/lowering suspension
lingo75
Hi All - new here!
Just got an 08 TDV8 yesterday (she is a beaut!) all has been well except almost every time i adjust the suspension i get a loud buzzing when its executing and when this happen i dont get a message to say its 'finished'
if i then change the setting again the noise will go but then come back when it appears to have 'finished' sometimes it just goes when i select drive, other times it stays on for a long while...
Help! Embarassed
Post #394779 Thu Sep 12 2013 4:32pm
roscopcoltrane
2008 Range Rover Sport TDV8 HSE Zermatt Silver
I have the same issue, Indy says its the suspension pump, noise comes from just south of front nearside wheel, needs investigating, not a massive issue just annoying Very Happy
Post #394780 Thu Sep 12 2013 4:43pm
lingo75
Cheers Rosco!
I'll give dealer a ring - warrantee!
Post #394782 Thu Sep 12 2013 4:57pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello Lingo.
First, welcome to the forum.
The loud buzzing sound is most likely the aircompressor for the suspension.
Itīs located just under the rear door on the left hand side of the car.
A common fault is that the workshop lift the car, not in the intended hole in the subframe of the car,
but put the jack in the drainhole under the compressor, and lifts.
Then the aluminium frame that holds the compressor brakes, and the compressor is "loose"
in itīs compartment, that gives a very loud buzzing sound.
The compressor works, but itīs annoying.
When You alter the suspension from normal to low or to high,You dont get a
message that says that it is done, just a Little "Icon" in the central info window,
that shows your setting.
To see when it is ready, You have to look at the side of the switch, when the Little light stops blinking, it is done.
Hope that this was of any help.
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #394792 Thu Sep 12 2013 6:09pm
lingo75
Max - you ledge
What a very nice gang i have just joined - hurrah!
Thumbs Up Cool http://www.rrsport.co.uk/images/veh/java_black.gif
Post #394798 Thu Sep 12 2013 6:30pm
