![]() | Home > Maintenance & Modifications > How to Run cable throught upper tailgate ? |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Not sure it's possible.
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
+ 1 16MY Estoril Blue SVR............. 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
The only way to run the cable is around the upper tailgate and then put a small hole in the rubber. It is a real fiddly job to get right as you also need to have the lower tailgate up at the same time (bit not too much) I use a piece of paracord to stop the upper tailgate going up too much.
| flydive Member Since: 16 May 2007 Location: South Posts: 1213
Same here '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
| mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705
+4 then |
| Kensta Member Since: 17 Feb 2011 Location: North east Posts: 702
Sounds like quite a job then!? Java black 2006 |
Do u mean u ran the cable from top to bottom on the inside the upper tailgate and disguised it with duck tape? that sounds like a plan Java black 2006 |
Yes, check this thread
| All times are GMT |
