Home > Maintenance & Modifications > How to Run cable throught upper tailgate ?
Kensta
Anybody on here know how to strip down rear upper tailgate to run a cable from the number plate light fitting up to the top of the tailgate under the spoiler? Pls let me know Thumbs Up Java black 2006
Post #384462 Sat Jun 01 2013 9:09am
Not sure it's possible.
My rear camera feed is run along the recess in the profile and stuck on with strips of black duck tape. RRS gone
Post #384549 Mon Jun 03 2013 9:13am
PEACHY
+ 1 16MY Estoril Blue SVR.............
Post #384552 Mon Jun 03 2013 9:15am
Bodsy
Site Sponsor
The only way to run the cable is around the upper tailgate and then put a small hole in the rubber. It is a real fiddly job to get right as you also need to have the lower tailgate up at the same time (bit not too much) I use a piece of paracord to stop the upper tailgate going up too much.
I also don't try feeding the av phono plug through that hole as I use some custom wiring to keep all the cables in one thin cable instead of power and video seperately. Then connect them in the tailgate housing. You need to drill a small hole through the tailgate handle (or a big hole if you keep the phono connector on!) Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #384555 Mon Jun 03 2013 9:27am
flydive
Same here '08 RRS TDV8
Post #384557 Mon Jun 03 2013 10:06am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
+4 then Laughing
Post #384576 Mon Jun 03 2013 4:52pm
Kensta
Sounds like quite a job then!? Java black 2006
Post #384579 Mon Jun 03 2013 5:50pm
Kensta
Do u mean u ran the cable from top to bottom on the inside the upper tailgate and disguised it with duck tape? that sounds like a plan Java black 2006
Post #384580 Mon Jun 03 2013 5:51pm
flydive
Yes, check this thread
http://rrsport.co.uk/forum/topic20219.html '08 RRS TDV8
Post #384581 Mon Jun 03 2013 6:05pm
