![]() | Home > Technical > Cruise control working intermittently , Any ideas pls? |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Mine did this and over the course of a year I finally managed to get it fixed (under warranty thankfully). Problem used to be cured by a system reset (stopping and restarting the engine).
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 702 ![]() ![]() ![]() |
Bugga mines not under warranty. |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
The clock spring on these is a well known fault, not that expensive, and from your symptoms sounds like a classic case |
Whats the clock spring? How do I get that fixed? |
strusal Member Since: 09 Mar 2011 Location: lonodn Posts: 5 ![]() ![]() ![]() |
My 2006 Sport cruise does the same. The cruise will work fine for a while then will just stop. Turning the engine off will sometimes work but not always. Had it looked at last year but the cruise worked fine for the mechanic and he couldn't find a fault on the computer. Really frustrating. Joyfully it has just developed an air suspension fault (after driving through the wilds of North London !) leaving the suspension fully lowered giving a really bouncy ride. I will be booking it in for a double service. |
Mite b a sensor problem with yor suspension strusal I've heard it's common with the earlier models apparently |
colin107 Member Since: 26 Feb 2011 Location: essex Posts: 2 ![]() ![]() ![]() |
Hi
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
simon1233
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
The man knows his stuff ![]() Common issue, and a new loom is around £15, and takes 10 mins to fit |
Which wheel did he mean?
Which loom costs 15GBP you're talking about is that clock spring?
The loom in behind the airbag in the steering wheel |
