Home > Technical > Cruise control working intermittently , Any ideas pls?
Kensta
Hi, my cruise control has just started to not light up sometimes when I operate it on steering wheel and so it doesn't work. I've noticed if I've had my car turned off then use it again the cruise may work for a bit then it stops again, this just started happening tonight. ANy ideas pls? Mines a 2006 tdv6 hse
Post #295949 Wed Apr 13 2011 11:39pm
simon1233
Mine did this and over the course of a year I finally managed to get it fixed (under warranty thankfully). Problem used to be cured by a system reset (stopping and restarting the engine).
Land Rover were really confused as the fault did not leave any fault codes in the system. I had 3 new switch packs and clock springs (connector in the steering column which takes the signals from the steering wheel to the car), numerous wiring checks and finally they opened up the ECU and found loads of silica gel, this excess of gel was removed and the car hasn't done it since. Don't know if the gel was moving and causing some problems or if the combination of all their efforts was finally successful.
Hopefully your car will have a fault code in the system (and that you have a warranty to pay for this).
Post #295971 Thu Apr 14 2011 9:03am
Kensta
Bugga mines not under warranty. Crying or Very sad
Post #296100 Fri Apr 15 2011 8:35am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
The clock spring on these is a well known fault, not that expensive, and from your symptoms sounds like a classic case
Post #296165 Fri Apr 15 2011 2:26pm
Kensta
Whats the clock spring? How do I get that fixed?
Post #296169 Fri Apr 15 2011 2:59pm
strusal
United Kingdom 2006 Range Rover Sport TDV6 S Zambezi Silver
Cruise control
My 2006 Sport cruise does the same. The cruise will work fine for a while then will just stop. Turning the engine off will sometimes work but not always. Had it looked at last year but the cruise worked fine for the mechanic and he couldn't find a fault on the computer. Really frustrating. Joyfully it has just developed an air suspension fault (after driving through the wilds of North London !) leaving the suspension fully lowered giving a really bouncy ride. I will be booking it in for a double service.
Post #297242 Mon Apr 25 2011 4:01pm
Kensta
Mite b a sensor problem with yor suspension strusal I've heard it's common with the earlier models apparently
Post #297306 Tue Apr 26 2011 9:06am
colin107
England 2005 Range Rover Sport TDV6 HSE Santorini Black
Hi
My cruise control has the same problem and now it seems to of stopped working.
I have just had my RR re mapped and lowered by a computer.
When I mentioned to the guy (who worked for RR for 15 yrs) about the cruise he told me to change the loom behind the wheel as all the turning does wear out the wires and causes the problem.
He said it was a common prob and now its not working at all I had better call him back....the money pit continues to open.. CW
Post #298186 Thu May 05 2011 5:12pm
gruodiz
Lithuania
simon1233
do you mean ECU engine control unit which sits behind the battery or any other module for Cruise Control? I don't even know if there's separate module for cruise control?
Was that ecu full of silica gel from factory?
Sorting the same problem now
Thank you
Post #377212 Sun Mar 17 2013 7:23pm
Disco_Mikey
The man knows his stuff Thumbs Up
Common issue, and a new loom is around £15, and takes 10 mins to fit
Post #377246 Sun Mar 17 2013 10:32pm
gruodiz
Lithuania
Which wheel did he mean?
I used datalogger to check each button on sterring wheel pressed and at the same time turned steering wheel from full left to full right. Did the same with all buttons and with no problems in voltage from pressed button but the cruise works from time to time. No error codes stored.
Post #377248 Sun Mar 17 2013 10:37pm
gruodiz
Lithuania
Which loom costs 15GBP you're talking about is that clock spring?
Clock spring costs much more.
Post #377635 Wed Mar 20 2013 7:58pm
Disco_Mikey
The loom in behind the airbag in the steering wheel
Post #377652 Wed Mar 20 2013 9:42pm
