Home > General > RR sport transmission fault
steverrsport
Hi, got a 2006 RR Sport, after about 20 mins driving it comes up transmission fault.
There is no lack of power and all gears change as normal.
HELP Sad
Post #377165 Sun Mar 17 2013 9:03am
simple1
Is it just this fault or are other faults coming up as well? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377166 Sun Mar 17 2013 9:18am
steverrsport
Hi, just comes up transmission fault after driving about 20 minutes. No other warnings.
If i stop the car and switch the ignition off it resets it, then i can drive another 10 mins and it comes back on.
The car still drives fine and changes through the gears as normal.
It has had the battery and alternator changed as i read this was connected.
when the code comes up it doesn't affect the driving of the car at all.
Steve
Post #377167 Sun Mar 17 2013 9:36am
simple1
You will need codes read then to find out what is triggering warning. As voltage fluctuation is the the most common cause, and you have covered that, there is obviously a more deep routed problem. Am sure there will be someone local to you who can do this or a trip to a local garage or dealer is in order 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377168 Sun Mar 17 2013 9:55am
steverrsport
I forgot to say that it only seems to happen when using the car over 40 mph.
Post #377169 Sun Mar 17 2013 9:57am
PEACHY
Had the same problem - it does need to be read and a fault code found but mine was a temperature sensor - it cost £15 and was fitted by the RAC - never had a problem since. Thumbs Up
Good luck. 16MY Estoril Blue SVR.............
Post #377170 Sun Mar 17 2013 10:03am
steverrsport
Thanks for the replies.... do you know if the fault has to be showing for the rac or garage to be able to find the fault with the diagnostics, as it does clear for a while once the ignition is off?
Post #377171 Sun Mar 17 2013 10:15am
simple1
If the fault clears when you restart it might not be recorded in the log, but theory says all faults should be recorded. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377172 Sun Mar 17 2013 10:23am
PEACHY
Mine had cleared but was found via the RAC diagnostic reader.
Smile 16MY Estoril Blue SVR.............
Post #377174 Sun Mar 17 2013 10:28am
Disco_Mikey
It could be many things, from a brake switch to something more sinister.
A diagnostic session at an indy specialist would be money well spent Thumbs Up
Post #377176 Sun Mar 17 2013 10:49am
steverrsport
Had the rac out, not good news
It came up torque converter and may go into limp mode.
Only had the car on the 16/3/13 at 14:30 warning light came on at 16:00 only done 42 miles Sad
Being recovered back to where we had it from !!!
Post #377202 Sun Mar 17 2013 6:30pm
simple1
That's not so good! Hopefully guy you got it from will do the right thing and get it sorted. Have to say its the first torque converter failure I have heard of, although heard of plenty with gearbox warnings including my own. In my case it was the ECU under the battery filled with water after battery box was not refitted correctly after body was removed to replace turbos. Reason I asked if there were other warnings was that mine also had suspension warnings randomly popping up.
Good luck, hopefully tomorrow brings better news. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377205 Sun Mar 17 2013 6:57pm
PEACHY
Sad sorry to hear that mate - every time I get a error message I see £ signs - these motors are good when there good but expensive when there bad - was it a reputable garage ? - I test drove mine & thought nothing was wrong - within hours - amber warning lights Censored had a right scrap with the seller - but I've kept with it & although its now 7 years old its the best motor I've ever had - really hope they sort it for you. Thumbs Up 16MY Estoril Blue SVR.............
Post #377221 Sun Mar 17 2013 8:32pm
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
Had the same on mine last year..
Turned out to be a simple brake switch on the pedal.
Post #377223 Sun Mar 17 2013 8:41pm
Disco_Mikey
Re: RR sport transmission fault
[quote="steverrsport"]Had the rac out, not good news
Being recovered back to where we had it from !!![/quote
What was the actual fault code? I had a fault code once that was something along the lines of torque signal invalid (along with a voltage fault)
Net result was a faulty EGR valve Thumbs Up
Post #377244 Sun Mar 17 2013 10:28pm
