![]() | Home > General > RR sport transmission fault |
Is it just this fault or are other faults coming up as well? 2x TDV6. SE and HSE. Both returned to sender with issues👀
steverrsport Member Since: 17 Mar 2013 Location: wolverhampton Posts: 11 ![]() |
Hi, just comes up transmission fault after driving about 20 minutes. No other warnings.
You will need codes read then to find out what is triggering warning. As voltage fluctuation is the the most common cause, and you have covered that, there is obviously a more deep routed problem. Am sure there will be someone local to you who can do this or a trip to a local garage or dealer is in order 2x TDV6. SE and HSE. Both returned to sender with issues👀
I forgot to say that it only seems to happen when using the car over 40 mph. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Had the same problem - it does need to be read and a fault code found but mine was a temperature sensor - it cost £15 and was fitted by the RAC - never had a problem since. |
Thanks for the replies.... do you know if the fault has to be showing for the rac or garage to be able to find the fault with the diagnostics, as it does clear for a while once the ignition is off? |
If the fault clears when you restart it might not be recorded in the log, but theory says all faults should be recorded. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mine had cleared but was found via the RAC diagnostic reader.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
It could be many things, from a brake switch to something more sinister.
Had the rac out, not good news
That's not so good! Hopefully guy you got it from will do the right thing and get it sorted. Have to say its the first torque converter failure I have heard of, although heard of plenty with gearbox warnings including my own. In my case it was the ECU under the battery filled with water after battery box was not refitted correctly after body was removed to replace turbos. Reason I asked if there were other warnings was that mine also had suspension warnings randomly popping up.
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 ![]() ![]() ![]() |
Had the same on mine last year..
[quote="steverrsport"]Had the rac out, not good news
