![]() | Home > General > Range Rover Gone Bang |
| 5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33
test |
sorry mate forgot to add that bit
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
when you say towed, i assume you mean on a low loader? I thought towing a RRS would mess up the diffs or something |
| AntRover Member Since: 28 Feb 2013 Location: Warwickshire Posts: 50
Did it turnover when trying to start it after it had died the last time? 2018 RR Velar R-Dynamic, Silver/Ebony, Privacy Glass, lots of toys
Hi guys
| P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144
Gutted for you |
The cambelt was booked for first week in april, |
Well hopefully it'll be something cheap and simple |
Sounds like something on the timing side has failed (valve, valve spring, cam belt) or some part of the turbo letting go.
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Common misunderstanding. You can't tow a 4x4 wheel free ie with two wheels on the ground as this will tear centre diff to bits. Issue with most range rovers is auto box. If you tow them too far then the auto box suffers from oil starvation as the pump is powered by input shaft from engine. As any bang from a land rover engine is never good, I sympathise deeply for your plight, as sat in same situation as you for last 7 weeks. 2x TDV6. SE and HSE. Both returned to sender with issues👀 TDV8 Sport HSE...... Gone. Loved it but it didn't love me!! Now rolling in MY10 Fullfat TDV8 Vogue. Slammed it to go round corners🙈 Cruising daily #56 mph in a Volvo V8. 😱 Lots of other toys in the cupboard...😜 |
so the rac pulling my car with all 4 wheel on the ground should be fine..
Normally this is without all the ancillaries (turbo, manifolds, starters, alternator etc)... 2018 RR Velar R-Dynamic, Silver/Ebony, Privacy Glass, lots of toys
they should be able to move mine from my old engine tho, if there ok of course |
Yes... I guess await diagnosis... fingers crossed eh! 2018 RR Velar R-Dynamic, Silver/Ebony, Privacy Glass, lots of toys
| All times are GMT |
