![]() | Home > General > Range Rover Gone Bang |
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186
Seems to be a common problem. |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162
Scotty, if it WAS this failure, then this is the same as mine, LR funded a replacement 100%. I had a mixture of LR and Indi Service stamps in the book. My Timing belt had been changed 1000 miles before the failure. Give me a call tomorrow. Can you get the garage to take a couple of pics of the failure point, My guess is it will look like this...... Mine.....
Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
| sasdiscos Member Since: 10 Mar 2013 Location: deep within Posts: 7
That's just poor. Hope you get it sorted. |
| dirtybarrys Member Since: 23 May 2007 Location: UK Posts: 18
Was there any progress on this? Same thing has just happened to my, 64k miles and 2007 RR history and specialist RR service with full RR parts receipts. |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Least you got 64k, mine got to 49 then threw clogs in air. |
| 5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33
Hi Guys
My Sport is still with the dealer. The dealer has been first class to date and has forwarded the relevant details to RR Customer Service (tel 0870 5000500) who say they are in conversation with the dealer. |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Beg's the question, is it possible to fit the latest oil pump casing to pre 09 cars. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Scroll down and read the post by "big Nick"
Update:
| pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 |
I think you should name the dealer a lot of the guys on her would like a helpful dealer L405 Loire Blue Swift Conqueror 645 Abarth 500c |
Yes you can to 07 and 08 engines. Although it tales about 7-1/2 hours, so not a cheap dealer fix..... Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
PJB,
Hey guys
