![]() | Home > General > Range Rover Gone Bang |
| oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148
Are you using Warranty Direct for this job? 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes... |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532
Dragon Engines, another "re-conditioning" specialist |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162
At least the warranty co have agreed to foot the bill |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
I just wonder - if, - in the future, there should an engine problem would Warranty Direct have indigestion because the car's history showed that it had not been repaired by Land Rover ! |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Wouldn't think so as this appears to be their approved repairer 2x TDV6. SE and HSE. Both returned to sender with issues👀
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
I am going to book my car in for a new oil pump, is there anything else that I need to change whilst the front of the car is stripped down??? It had new cam belt 12 months ago. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
You could change the water pump which you need to remove the timing belt to do anyway. Istr water pump is about £70 |
Do no harm to replace the belt again either. Doesn't do them any good being under tension then removed and refitted. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Prior to booking my car in for the updated oil pump, can I just re confirm that the pump I need is the one fitted to the 3 litre engine - the latest version being LR013487. Also as the car has only covered 35k, is it worth changing the water pump? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
there is one for pre 06A99999 1348651
Latest type oil pump now fitted by main dealer €400 all in |
not a bad price at all |
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186
Did you get any other bits changed at the same time? 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
