![]() | Home > Technical > Knock when i press the brake pedal quickly |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Could be a number of things...
You don't have a rogue golf ball rolling about the car do you.......I joke, but was found to be the problem in my fathers car many moons ago |
lee551247 Member Since: 23 Aug 2012 Location: Cheltenham Posts: 287 ![]() ![]() |
I hear a knocking sound from the rear of the car when I go over potholes but the noise comes from the front of the car, Does nobody else's do this then? Its not a land rover 'charcteristic'! is it?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4516 ![]() ![]() ![]() |
Front lower suspension arm bushes and rear anti roll bar bushes |
Thanks Mikey,
Most probably the bushes but I've known pads to move around in the past, hence asking when brakes were done.
A good garage will ![]() |
Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70 ![]() ![]() ![]() |
As Disco Mikey said.
Well 9 hours on and my lower suspension nearside is still not off the car!
Can you shorten the thread on the ball joint? The screw type splitters are about 1cm too small so chop a bit off the thread.
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
yes, i have this knock too, all new= all smooth |
I have shortened the thread but the screw type I have won't go over the knuckle.
Just an update:
