Home > Technical > Knock when i press the brake pedal quickly
lee551247
I have a 2008 sport TDV8 and when braking smoothly its fine but if I stab the brake pedal quickly I get a knock, is this normal?
Thanks
Post #363903 Wed Nov 21 2012 10:43am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Could be a number of things...
Do you hear any knocking sounds when you drive over potholes? Do you hear a click if you apply brakes when reversing? Is there any play on your steering wheel? When were the brake pads last changed? How long has this been a problem?
Have you ever had the anti roll bar bushes changed?
Post #363905 Wed Nov 21 2012 10:55am
You don't have a rogue golf ball rolling about the car do you.......I joke, but was found to be the problem in my fathers car many moons ago Laughing ON THE WAY: BMW F21 M140i
Post #363906 Wed Nov 21 2012 10:58am
lee551247
I hear a knocking sound from the rear of the car when I go over potholes but the noise comes from the front of the car, Does nobody else's do this then? Its not a land rover 'charcteristic'! is it?
I have booked the car in with land rover with a complaint of suspension knocking and slight steering wobble on the odd occasion so hopefully they will be able to sort it as the warranty runs out in March
No there are no golf balls in the boot lol!
Post #363910 Wed Nov 21 2012 11:13am
Disco_Mikey
Front lower suspension arm bushes and rear anti roll bar bushes Thumbs Up
Post #363926 Wed Nov 21 2012 12:50pm
lee551247
Thanks Mikey,
Will i need to request that they change these or will they naturally come across them when they inspect?
Post #363932 Wed Nov 21 2012 1:01pm
kav1187
Most probably the bushes but I've known pads to move around in the past, hence asking when brakes were done.
LR will probably tell you that the wishbones are fine and then act surprised when the noise doesn't go away Laughing
Post #363934 Wed Nov 21 2012 1:34pm
Disco_Mikey
lee551247 wrote:
Thanks Mikey,
A good garage will Laughing
Post #363952 Wed Nov 21 2012 3:15pm
Disco_Mikey
lee551247 wrote:
Thanks Mikey,
Post #363953 Wed Nov 21 2012 3:15pm
Stefan.lajszczuk
United Kingdom 2006 Range Rover Sport SDV6 SE Rimini Red
As Disco Mikey said.
I'm replacing my lower suspension arm on nearside and arb bushes tomorrow morning as I'm getting the same sound under braking.
I'll post how i got on once it's done!
Post #364000 Wed Nov 21 2012 10:10pm
Stefan.lajszczuk
Well 9 hours on and my lower suspension nearside is still not off the car!
I've removed 3 of the bolts with not too much difficulty, but the ball joint won't come away from the wheel hub assembly.
I've tried large hammers to shock it, pry bars, even blowtorch to try to hear it but the blighter wont budge.
My dads got a ball joint pulled of the screw type but this is too small to fit round the arm.
So at the moment its in my dads garage, over an inspection pit with no sign of movement soon!
Can anyone shed any light on what else to try?
I'm trying to get a bigger puller in the morning to continue trying.
If anyone can advise me or has a big puller for the job that I can borrow in West Yorkshire I'd be most grateful
Post #364104 Thu Nov 22 2012 8:23pm
kav1187
Can you shorten the thread on the ball joint? The screw type splitters are about 1cm too small so chop a bit off the thread.
With mine, my splitter broke on me so i had no choice but to hammer it out. Just go to town on it with the hammer Smile
How about a splitter like in my build thread?
http://www.rrsport.co.uk/forum/topic28424.html
Post #364113 Thu Nov 22 2012 9:09pm
CUCO
Spain
yes, i have this knock too, all new= all smooth
Post #364119 Thu Nov 22 2012 9:28pm
Stefan.lajszczuk
I have shortened the thread but the screw type I have won't go over the knuckle.
I have looked at the splitter bars but the ones I have seen here are not wide enough.
Hopefully a local garage owner my dad knows will lend us one.
Once its off I only have about 1/2 hours work before re alignment.
It's been one of them days today. Never in a month of Sundays would I have imagined it being so blooming tight
Post #364133 Thu Nov 22 2012 10:11pm
Stefan.lajszczuk
Just an update:
I had to remove the brake disc, caliper and the arm holding these on and I put the whole unt in a vice and with some good old swings with a hammer the ball joint came out.
Then another nut became seized within the metal part of the bush and in turn I was unable to knock this out at all. In the end I used a grinder to cut the head off the bolt, then cut through the wishbone itself and the metal surrounding the bush!!!
This task was not pleasant and left my father and I very cheesed off to say the least, but we did it and all the new components are on the car, tight as they should be.
I've left the car at my fathers until Monday as this is when the alignment is getting done. I won't risk driving it until its been aligned properly after so much faffing about with the suspension.
I don't envy anyone wanting to do this task as its a real pain!
Post #364274 Fri Nov 23 2012 11:12pm
