![]() | Home > Maintenance & Modifications > Off road bits |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
There are 2 extended modes after off road height.
| taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49
Have heard that, would just like to see it. Will have to o out and get stuck, always got the winch just in case |
I dont use my sport for off roading - i have other land rovers for that...or other people's sports!
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Isn't super extended accessed by getting it to go in to extended mode and then holding the raise button for a specified period of time?
| rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216
I thought the car put itself in the extra extended mode when it had all wheels off the ground |
It does for the first bit 1.5 inches, then you can do the previously mention method to get a bit more, clever stuff!! Range Rover Vogue Classic 3.9 V8 1992
handy for getting up them really big curbs you get |
I remember reading that if the car is in off road height and becomes grounded (sensed by load off the wheels and the TC working overtime) then it will automatically extend by a further amount (50mm?). At this point, one can ask for a little bit more (up to a total extra of 75mm?) by holding the raise button.
Correct. You must have your foot on the brake to get the second lift. You can fool it by putting block under the jack up point when in off road height, doors shut, engine running, lower and it will sense an obstruction and raise up. Going to try it soon. |
I was at LR Eastnor and they proved the myth that a RRS and a Disco cant have the same normal off road height is just that - ill see if i can dig out a photo. Mike
From LR's figures:
The sport has exactly the same ground clearance - the suspension when you get past it has the same clearance Mike
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
When I did my off road day at Luton Hoo, I asked the guy which car was the best off road.
On some off road days in my sport i have got further than defenders sometimes, the micky taking soon stops |
| All times are GMT |
