| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Off road bits |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | There are 2 extended modes after off road height.
|  Mon Jul 23 2012 10:43pm |
| taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49      | Have heard that, would just like to see it. Will have to o out and get stuck, always got the winch just in case  | ||
|  Mon Jul 23 2012 11:01pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | I dont use my sport for off roading - i have other land rovers for that...or other people's sports!
|  Tue Jul 24 2012 4:37pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Isn't super extended accessed by getting it to go in to extended mode and then holding the raise button for a specified period of time?
|  Tue Jul 24 2012 6:04pm |
| rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216    | I thought the car put itself in the extra extended mode when it had all wheels off the ground | ||
|  Tue Jul 24 2012 6:16pm |
| taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49      | It does for the first bit 1.5 inches, then you can do the previously mention method to get a bit more, clever stuff!! Range Rover Vogue Classic 3.9 V8 1992
|  Tue Jul 24 2012 6:18pm |
| rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216    | handy for getting up them really big curbs you get  | ||
|  Tue Jul 24 2012 6:22pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I remember reading that if the car is in off road height and becomes grounded (sensed by load off the wheels and the TC working overtime) then it will automatically extend by a further amount (50mm?). At this point, one can ask for a little bit more (up to a total extra of 75mm?) by holding the raise button.
|  Tue Jul 24 2012 6:23pm |
| taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49      | Correct. You must have your foot on the brake to get the second lift. You can fool it by putting block under the jack up point when in off road height, doors shut, engine running, lower and it will sense an obstruction and raise up. Going to try it soon.   | ||
|  Tue Jul 24 2012 6:36pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | I was at LR Eastnor and they proved the myth that a RRS and a Disco cant have the same normal off road height is just that - ill see if i can dig out a photo. Mike
|  Tue Jul 24 2012 10:58pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | From LR's figures:
|  Tue Jul 24 2012 11:17pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | The sport has exactly the same ground clearance - the suspension when you get past it has the same clearance Mike
|  Wed Jul 25 2012 2:33am |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796    | When I did my off road day at Luton Hoo, I asked the guy which car was the best off road.
|  Wed Jul 25 2012 8:08am |
| taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49      | On some off road days in my sport i have got further than defenders sometimes, the micky taking soon stops  | ||
|  Wed Jul 25 2012 7:56pm |
| Posting Rules
