Home > Maintenance & Modifications > Off road bits
taff
Wales 2006 Range Rover Sport 4.4 V8 SE Zermatt Silver
Off road bits
My Johnson Rods have turned up which will give me an extra 2.5 inch lift, got to wait till next wed as stuck on a tug boat till then. Transmission bash plate on its way, got to wait till mid October for rear diff plate as there has been a manufacturing problem Evil or Very Mad
When bits are on i will post some pics if any one is interested, also think about getting a superchip remap done, got a 4.4 v8, anyone done on with this engine?
Also going to fool vehicle that its hung up and activate extended mode in the suspension as i have never seen how high they go, apparently its much higher than standard off road height. Should be fun. Laughing
Post #351608 Mon Jul 23 2012 7:09pm
mse
There are 2 extended modes after off road height.
Extended mode and super extended - running in them apparently can cause transmission damage - but they go high. Mike
2014 Facelift Discovery
Post #351623 Mon Jul 23 2012 11:43pm
taff
Have heard that, would just like to see it. Will have to o out and get stuck, always got the winch just in case Thumbs Up Range Rover Vogue Classic 3.9 V8 1992
101 Forward Control GS 1977
Range Rover Sport SE 4.4 V8 2006
Post #351626 Tue Jul 24 2012 12:01am
mse
I dont use my sport for off roading - i have other land rovers for that...or other people's sports!
BTW - ive seen it, it didnt take us a lot to get it into extended - super extended was harder Mike
Post #351686 Tue Jul 24 2012 5:37pm
Isn't super extended accessed by getting it to go in to extended mode and then holding the raise button for a specified period of time?
I think the system drops back to normal off road height after only a short period of time to prevent damage to the drivetrain, however.
One thing that puzzles me is that, as the RRS is a D3 underneath, why can't the RRS have the same ground clearance as the D3 in off road mode? Presumably the wishbones are slightly shorter but not so much as to make much of a difference. Presumably the air springs/dampers are sufficiently different to make long term "elevated driving" detrimental to their reliability. It's annoying really - if the RRS could be driven in D3 ride height off road, it would make it even more accomplished... 2012 SDV6 - it's missing a couple of cylinders
Post #351694 Tue Jul 24 2012 7:04pm
rstebbings
I thought the car put itself in the extra extended mode when it had all wheels off the ground
Post #351698 Tue Jul 24 2012 7:16pm
taff
It does for the first bit 1.5 inches, then you can do the previously mention method to get a bit more, clever stuff!! Range Rover Vogue Classic 3.9 V8 1992
Post #351699 Tue Jul 24 2012 7:18pm
rstebbings
handy for getting up them really big curbs you get Whistle
Think I will keep mine in std mode Thumbs Up
Post #351700 Tue Jul 24 2012 7:22pm
I remember reading that if the car is in off road height and becomes grounded (sensed by load off the wheels and the TC working overtime) then it will automatically extend by a further amount (50mm?). At this point, one can ask for a little bit more (up to a total extra of 75mm?) by holding the raise button.
Never tried it though. 2012 SDV6 - it's missing a couple of cylinders
Post #351701 Tue Jul 24 2012 7:23pm
taff
Correct. You must have your foot on the brake to get the second lift. You can fool it by putting block under the jack up point when in off road height, doors shut, engine running, lower and it will sense an obstruction and raise up. Going to try it soon. Shocked Range Rover Vogue Classic 3.9 V8 1992
Post #351704 Tue Jul 24 2012 7:36pm
mse
I was at LR Eastnor and they proved the myth that a RRS and a Disco cant have the same normal off road height is just that - ill see if i can dig out a photo. Mike
Post #351734 Tue Jul 24 2012 11:58pm
From LR's figures:
RRS:
Ground clearance off-road height: 227mm
Standard ride height: 172mm
D4:
Ground clearance: Up to 310mm (air suspension)
Standard ride height: 185mm
The D4 also has the better approach, break over and departure angles (especially when compared to the WAG version of the RRS).
Where is the myth? I'd dearly love to see how the RRS gets better ground clearance than the D4 - would certainly be a nice little ace up the sleeve for those pub bores telling us how crap the RRS is off road Yawn 2012 SDV6 - it's missing a couple of cylinders
Post #351737 Wed Jul 25 2012 12:17am
mse
The sport has exactly the same ground clearance - the suspension when you get past it has the same clearance Mike
Post #351742 Wed Jul 25 2012 3:33am
When I did my off road day at Luton Hoo, I asked the guy which car was the best off road.
In his opinion, he said he would choose a FFRR, foLlowed but an RRS, which surprised me as I thought he'd say a Disco.
I'd say he was fairly qualified to judge, so must be something in it Thumbs Up ON THE WAY: BMW F21 M140i
Post #351760 Wed Jul 25 2012 9:08am
taff
On some off road days in my sport i have got further than defenders sometimes, the micky taking soon stops Laughing Range Rover Vogue Classic 3.9 V8 1992
Post #351840 Wed Jul 25 2012 8:56pm
