Home > General > Random draining of Battery
Meccles
Australia 2013 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Am sad my 2010 TDV8 was taken away on flatbed to dealers. They are trying to find reason for random draining of battery. Happens about every two months, car is locked, left overnight, come back in morning and lights are flashing, things going beep/whirr, and battery voltage going down down down. Lowest we have seen is 2 Volts. New batteries gone in, upper tailgate switch checked. car checked and goes to "sleep" correctly. LR dealer can't seem to find a fault. Issue is, as soon as car is started, voltage returns to normal, fault codes clear, all appears ok. Until next time...... Confused Suggestions?? The dealer is also at a loss. SWMBO owns this car I get to drive occasionally Smile
Post #338906 Fri Apr 06 2012 6:26am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
air suspension fault, system wakes up every few hours and tries to adjust what it thinks is a lean in the suspension, using precious power
(maybe) ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #338935 Fri Apr 06 2012 12:07pm
shakeapaw
i concur, my mercedes e320 avantgarde had air suspension, they had to recall them to stop the suspension righting itself all the time, in theory it shoudnt happen, as the car is parked and stationary, however take your mercedes on a P & O ferry, lock it and see what happens. The suspension activates all the time due to the ferrys movement, and then it wont start, as the battery drains. 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #338938 Fri Apr 06 2012 12:28pm
Meccles
Possible. Where the car is left parked is not level, so that could be it. I haven't heard it trying to adjust, but when am asleep, don't here much! SWMBO owns this car I get to drive occasionally Smile
Post #339014 Sat Apr 07 2012 3:34am
rrsboy
perhaps it waking up is enough? depending on frequency/sensor readings etc, coupled with weak battery - might be enough to drain it?
just guessing Thumbs Up ============
Post #339062 Sat Apr 07 2012 6:42pm
Meccles
Sounds like me...just waking up is enough! Very Happy Though waking up to working car always puts a smile on my face. Lucky I am at work at moment so dealer has plenty of time for testing/trials. Will see what they come back with. SWMBO owns this car I get to drive occasionally Smile
Post #339118 Sat Apr 07 2012 11:15pm
Kensta
Meccles u mentioned in your first post of getting a new battery fitted and checking the upper tailgate why did u check the upper tailgate? Reason I'm asking is the other day I noticed my upper tailgate won't unlock and today my battery is totally flat car wouldn't start, is there a link between flat batts and the tailgate? Java black 2006
Post #339122 Sun Apr 08 2012 1:42am
Meccles
There is heaps of rlinks/reference on this forum to a known issue with the upper taikgate switch failing, which causea a short, which drains the battery down. I think particularly in UK (salted roads perhaps?). You can buy new switches on ebay. SWMBO owns this car I get to drive occasionally Smile
Post #339147 Sun Apr 08 2012 10:37am
Kensta
Cheers meccles il look into that Java black 2006
Post #339149 Sun Apr 08 2012 10:50am
Meccles
Update, looks like it may have been a faulty bonnet switch. Same type of issue as upper tailgate just opposite end of car. SWMBO owns this car I get to drive occasionally Smile
Post #339297 Tue Apr 10 2012 12:25am
Kensta
Crazy cars Java black 2006
Post #339320 Tue Apr 10 2012 11:23am
Meccles
Car failed again, Was at dealer for week while they tried to get it to fail/drain battery. New battery fitted, new software loaded, new bonnet switch. Worked fine for 6 weeks. Then fails to start in morning, battery dead flat. Sad What to say? SWMBO owns this car I get to drive occasionally Smile
Post #345634 Sat Jun 02 2012 6:19pm
baxc
have you replaced the upper tailgate switch or just checked it wasnt corroded i had the same prob took me 3 weeks of testing to find it was the upper tailgate switch i would replace the switch m8
Post #345688 Sun Jun 03 2012 10:40am
I wonder if the alternator (generator) is starting to fail leading to a steadily draining battery. Just a thought. 2012 SDV6 - it's missing a couple of cylinders
Post #345697 Sun Jun 03 2012 12:10pm
Meccles
I will hit the dealer up to fit a new upper tailgate switch. Have asked them already about the alternator, they confirmed that there had been some failures on earlier TDV8 (2007-2009) but that as yet they had not seen a 2010 spec alternator fail. Not that this is impossible I mean this is a Land Rover! Car just finished a bit of off roading and got really dirty/dusty, and had good clean. The upper tailgate was physically full of dust, so maybe this is related, washing all dirt out? Could be, wet/faulty switch. Can you waterproof the switch at all? Or just glue the upper tailgate down and remove switch altogether Laughing that would fix it! SWMBO owns this car I get to drive occasionally Smile
Post #346246 Fri Jun 08 2012 4:48pm
