![]() | Home > General > Random draining of Battery |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
air suspension fault, system wakes up every few hours and tries to adjust what it thinks is a lean in the suspension, using precious power
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
i concur, my mercedes e320 avantgarde had air suspension, they had to recall them to stop the suspension righting itself all the time, in theory it shoudnt happen, as the car is parked and stationary, however take your mercedes on a P & O ferry, lock it and see what happens. The suspension activates all the time due to the ferrys movement, and then it wont start, as the battery drains. 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154 ![]() ![]() ![]() |
Possible. Where the car is left parked is not level, so that could be it. I haven't heard it trying to adjust, but when am asleep, don't here much! SWMBO owns this car I get to drive occasionally |
perhaps it waking up is enough? depending on frequency/sensor readings etc, coupled with weak battery - might be enough to drain it?
Sounds like me...just waking up is enough! |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 701 ![]() ![]() ![]() |
Meccles u mentioned in your first post of getting a new battery fitted and checking the upper tailgate why did u check the upper tailgate? Reason I'm asking is the other day I noticed my upper tailgate won't unlock and today my battery is totally flat car wouldn't start, is there a link between flat batts and the tailgate? Java black 2006 |
There is heaps of rlinks/reference on this forum to a known issue with the upper taikgate switch failing, which causea a short, which drains the battery down. I think particularly in UK (salted roads perhaps?). You can buy new switches on ebay. SWMBO owns this car I get to drive occasionally |
Cheers meccles il look into that Java black 2006 |
Update, looks like it may have been a faulty bonnet switch. Same type of issue as upper tailgate just opposite end of car. SWMBO owns this car I get to drive occasionally |
Crazy cars Java black 2006 |
Car failed again, Was at dealer for week while they tried to get it to fail/drain battery. New battery fitted, new software loaded, new bonnet switch. Worked fine for 6 weeks. Then fails to start in morning, battery dead flat. |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
have you replaced the upper tailgate switch or just checked it wasnt corroded i had the same prob took me 3 weeks of testing to find it was the upper tailgate switch i would replace the switch m8 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
I wonder if the alternator (generator) is starting to fail leading to a steadily draining battery. Just a thought. 2012 SDV6 - it's missing a couple of cylinders
I will hit the dealer up to fit a new upper tailgate switch. Have asked them already about the alternator, they confirmed that there had been some failures on earlier TDV8 (2007-2009) but that as yet they had not seen a 2010 spec alternator fail. Not that this is impossible I mean this is a Land Rover! Car just finished a bit of off roading and got really dirty/dusty, and had good clean. The upper tailgate was physically full of dust, so maybe this is related, washing all dirt out? Could be, wet/faulty switch. Can you waterproof the switch at all? Or just glue the upper tailgate down and remove switch altogether |
