![]() | Home > Technical > 5 speed or 6 speed when in command shift? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
All gears are available in CS on my 2007 RRS 2012 SDV6 - it's missing a couple of cylinders
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
In Drive or CS, all gears are available. In Sport mode, only the first 5.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
No so for a 2.7 TDV6 - I used to think that because mine did not go into 6th but I tested it on a motorway and found it changes up to 5th as normal and as long as cruise speed (a steady speed) is over 80kph it will change into 6th after about a minute - if you are not driving relatively steady it will not go into 6th - I rarely see 6th around town in Sport mode but I tow my camper van in sport mode and it will get into 6th eventually. When not towing I do not find Sport mode to be much use. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Mine selects 6th at 50mph as long as the throttle is light
toeuk1 Member Since: 18 Sep 2011 Location: UK Posts: 29 ![]() ![]() ![]() |
My 07 TDV8 will be in 6th gear at about 2000 rpm doing 70 mph. If you are going too slow, command shift won't allow you to change up to the next gear. As long as I'm going fast enough, 6th is available using command shift. |
factoryfil Member Since: 02 Feb 2012 Location: Norwich Posts: 26 ![]() ![]() ![]() |
Thanks to everyone for your replies,I'll be going on some decent open roads this weekend,all being well I will find all the gears |
