Home > Technical > 5 speed or 6 speed when in command shift?
factoryfil
United Kingdom 2006 Range Rover Sport TDV6 S Java Black
Hi all, Newbie to the forum and a newbie to a rr sport,does anybody know if 6th gear is available when in command shift? doesn't shift and just stays in 5th on the display,can't quite tell if its going in, even in auto mode, I haven't been on a decent run as yet,I did read on hear somewhere that the box is self learning and adapts to individual driving styles,any advise or info would be apreciated
Post #330709 Thu Feb 02 2012 10:11pm
All gears are available in CS on my 2007 RRS 2012 SDV6 - it's missing a couple of cylinders
Post #330752 Fri Feb 03 2012 12:44am
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
In Drive or CS, all gears are available. In Sport mode, only the first 5.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #330755 Fri Feb 03 2012 2:23am
garrycol
Australia
Cheers,
Gordon
No so for a 2.7 TDV6 - I used to think that because mine did not go into 6th but I tested it on a motorway and found it changes up to 5th as normal and as long as cruise speed (a steady speed) is over 80kph it will change into 6th after about a minute - if you are not driving relatively steady it will not go into 6th - I rarely see 6th around town in Sport mode but I tow my camper van in sport mode and it will get into 6th eventually. When not towing I do not find Sport mode to be much use.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #330775 Fri Feb 03 2012 9:27am
Mine selects 6th at 50mph as long as the throttle is light
Not sure if the ratios are the same as the TDV8, but if you're doing 50mph and the revs are around the 1500 mark then you're in 6th RRS gone
Post #330777 Fri Feb 03 2012 9:55am
toeuk1
My 07 TDV8 will be in 6th gear at about 2000 rpm doing 70 mph. If you are going too slow, command shift won't allow you to change up to the next gear. As long as I'm going fast enough, 6th is available using command shift.
Post #330820 Fri Feb 03 2012 2:24pm
factoryfil
Thanks to everyone for your replies,I'll be going on some decent open roads this weekend,all being well I will find all the gears
Post #330949 Fri Feb 03 2012 11:48pm
