![]() | Home > General > Fuels......... |
| andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370
Right, an interesting experiment. Just been on a road trip and where possible I always use Shell in my JLR stuff as I've found the Td5's and V6's preffer it and produce the least amont of smog when bending the firewall with the loud pedal. So my run was 300 ish each way and I filled to the brim from quarter of a tank each way. The trip up hill I filled with V power and the trip back with common or garden Shell. Both ways took about the same time and where outside lane all the way. Going up gave 34 on the dash and coming back gave 31.
| Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586
I used to always put the good stuff in, since had a change of heart and think its all a big con and its a rip off as it is, why voluntarily pay more?
I'm trying to do the percentages and it probably works out better in favour of using more of the cheap stuff ! The 2.7 does run quieter on V and the 3.0 TdV in the Jag loved the V, like you say it is probably a rip off ! 08 2.7 RRS "S"
Since changing from supermarket diesel over to Shell "normal" diesel my both my TDv8's have not only run better, the fuel consumption is better by 3-4mpg (on the trip it's even better!) and I don't get a black cloud out the tailpipes if I floor the loud pedal 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
Did you see the top gear test with Alonso & his Ferrari F1 car where they ran it on the F1 Fuel then on normal forecourt juice. The results were very close and infact Alonso said that in some areas the normal fuel had a quicker throttle pick up than the F1 stuff |
Dont start me on the nitrogen filled tyres ffs ! 08 2.7 RRS "S"
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
I've run several 'fleet' test on fuel.
I wonder how much the atmosphere affects consumption ?? ie on the way up it rained most of the way and the way back it was dry and sunny ????? 08 2.7 RRS "S"
| mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297
Cost 10 per cent more, get 10 per cent better MPG, no difference to the wallet, use whatever you feel is better for your RRS |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368
Tim - having discussed this wiith a buyer at Asda HQ i was informed that the fuel they put in the tanks at their stores is from the same source as the main brands so should not make a difference other than in your wallet. |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
I admit, I got suckered into that one once (once I hasten to add)......correct, what a load of old S 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
The chemistry is there for nitro filling, but for it to work properly the tyre needs to be fitted and inflated in a nitro purged chamber, other wise you are just pressurising 10 litres of normal air with nitrogen, so the pressure is still unstable ! 08 2.7 RRS "S"
| lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052
Both the RRS and now the merc have had problems running on shell.
No matter what the fuel.........its way too B |
| All times are GMT |
