Home > General > Fuels.........
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
Fuels.........
Right, an interesting experiment. Just been on a road trip and where possible I always use Shell in my JLR stuff as I've found the Td5's and V6's preffer it and produce the least amont of smog when bending the firewall with the loud pedal. So my run was 300 ish each way and I filled to the brim from quarter of a tank each way. The trip up hill I filled with V power and the trip back with common or garden Shell. Both ways took about the same time and where outside lane all the way. Going up gave 34 on the dash and coming back gave 31.
Discuss 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #309013 Mon Aug 08 2011 2:37pm
Jonny Fresh
I used to always put the good stuff in, since had a change of heart and think its all a big con and its a rip off as it is, why voluntarily pay more?
Am I wrong? Should I go back to the good stuff?
Post #309020 Mon Aug 08 2011 2:48pm
andy r
I'm trying to do the percentages and it probably works out better in favour of using more of the cheap stuff ! The 2.7 does run quieter on V and the 3.0 TdV in the Jag loved the V, like you say it is probably a rip off ! 08 2.7 RRS "S"
RS 5
Post #309038 Mon Aug 08 2011 4:25pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
being of sceptical disposition (think "nitrogen in the tyres? what a load of Censored ") I'd like to see proof positive before changing from the cheapest, usually Tesco. Not hearsay, or opinion, just cold hard quantitative data. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #309180 Tue Aug 09 2011 4:36pm
Tim in Scotland
Since changing from supermarket diesel over to Shell "normal" diesel my both my TDv8's have not only run better, the fuel consumption is better by 3-4mpg (on the trip it's even better!) and I don't get a black cloud out the tailpipes if I floor the loud pedal 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #309182 Tue Aug 09 2011 4:43pm
Endjin
Scotland
Did you see the top gear test with Alonso & his Ferrari F1 car where they ran it on the F1 Fuel then on normal forecourt juice. The results were very close and infact Alonso said that in some areas the normal fuel had a quicker throttle pick up than the F1 stuff Confused Ofcourse, if you want to be a healthy cynic then you may argue that this just makes a nice marketing stance for Shell to sell more fuel on the forecourt...... but surely... Top Gear wouldn't fall for that, would they?...... Whistle 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #309183 Tue Aug 09 2011 4:45pm
andy r
Dont start me on the nitrogen filled tyres ffs ! 08 2.7 RRS "S"
RS 5
Post #309202 Tue Aug 09 2011 6:45pm
drdelrrs
I've run several 'fleet' test on fuel.
The UK has common prevailing winds and a two-way trip can easily have a variation of 10% on fuel used just because of this effect.
You'd need to plot a circuit very carefully and ensure you drove exactly the same if you really wanted the answer.
If you think your RRS runs better then that's a good enough reason.
Post #309203 Tue Aug 09 2011 6:51pm
andy r
I wonder how much the atmosphere affects consumption ?? ie on the way up it rained most of the way and the way back it was dry and sunny ????? 08 2.7 RRS "S"
RS 5
Post #309205 Tue Aug 09 2011 6:54pm
mike21
2009 Range Rover Sport TDV6 HSE Stornoway Grey
Cost 10 per cent more, get 10 per cent better MPG, no difference to the wallet, use whatever you feel is better for your RRS Thumbs Up 2019 BMW X3 2.0i M Sport in metalic black- Brilliant
2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone
2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone
2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone
Post #309210 Tue Aug 09 2011 7:28pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Tim - having discussed this wiith a buyer at Asda HQ i was informed that the fuel they put in the tanks at their stores is from the same source as the main brands so should not make a difference other than in your wallet.
Post #309219 Tue Aug 09 2011 8:31pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Rolling with laughter Rolling with laughter
I admit, I got suckered into that one once (once I hasten to add)......correct, what a load of old S Censored t Twisted Evil L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #309237 Tue Aug 09 2011 10:28pm
andy r
The chemistry is there for nitro filling, but for it to work properly the tyre needs to be fitted and inflated in a nitro purged chamber, other wise you are just pressurising 10 litres of normal air with nitrogen, so the pressure is still unstable ! 08 2.7 RRS "S"
RS 5
Post #309249 Wed Aug 10 2011 12:17am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Both the RRS and now the merc have had problems running on shell.
Usually when warming up and under accleration have had mis fire and the kangeroos, evrytime it has happened has been on shell fuel.
As for the orig post hard to tell wind direction can make just as big difference to mpg
Post #309251 Wed Aug 10 2011 1:14am
will_wonka
No matter what the fuel.........its way too B Censored y expensive Evil or Very Mad Evil or Very Mad
Brent crude now below $100 a barrel and oh what a surprise, the pump price still thinks its $125 a barrel - £1.36 Unl/litre.....someones making money and as to quote the Petrol Retailers Association..."its not us" W Censored s...........
We may be idiotic in this country when it comes to cohesive action, but we are not all balaclava wearing Kyle show watchers who communicate using uggs....... daylight robbery, plain and simple. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #309344 Wed Aug 10 2011 10:41pm
