| RRSPORT.CO.UK | ||
|  | Home > General > RRS air suspension |
| Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49    | Mine does this as well........it has done for almost 4 years (same side, mostly at the rear), I just get into the habit of putting it in access height when I'm parking overnight. I've asked the stealers about it, but they can't find anything (what a surprise!).
|  Fri Feb 05 2010 8:15pm |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | This is a reasonably common issue and can normally be put down to a faulty ride height sensor... dealer should be able to resolve fairly easily.  | ||
|  Fri Feb 05 2010 8:55pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | yap - have a search of my recent posts to see the fun I've had trying to get   | ||
|  Sun Feb 07 2010 11:21pm |
| ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750      | shmoogle is correct, should be an easy fix  | ||
|  Mon Feb 08 2010 9:01am |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | okay my dealer has finally admitted its a problem other than the height sensor - cue new air spring, air valve and something else tomorrow... will let you know if it works! | ||
|  Wed Feb 24 2010 9:04pm |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377    |
    L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles   RRS S/C factory built HST - Gone 45 others have been and gone! | ||
|  Wed Feb 24 2010 10:33pm |
| dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851    | My 08 TDV8 had a recall yesterday for the sensors, there was nothing wrong with the car but they were doing them al on my year.
|  Thu Feb 25 2010 2:51pm |
| A12DY B Member Since: 21 May 2008 Location: WEST MIDS Posts: 335    | mine is just being done now under warrenty as my air suspension was playing up | ||
|  Thu Feb 25 2010 3:00pm |
| 4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955      | So far my suspension has had, 1 compressor, 4 ride height sensors(recall) switch, pipework and now a new ride height control module on order.  (And a partridge in a pear tree............  | ||
|  Thu Feb 25 2010 3:47pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | edit : the whole air spring needed replacing in the end, but did solve the problem | ||
|  Mon Apr 19 2010 7:36pm |
| Posting Rules
 to fix it
  to fix it
