![]() | Home > General > RRS air suspension |
| Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49
Mine does this as well........it has done for almost 4 years (same side, mostly at the rear), I just get into the habit of putting it in access height when I'm parking overnight. I've asked the stealers about it, but they can't find anything (what a surprise!).
This is a reasonably common issue and can normally be put down to a faulty ride height sensor... dealer should be able to resolve fairly easily. |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391
yap - have a search of my recent posts to see the fun I've had trying to get |
| ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750
shmoogle is correct, should be an easy fix |
okay my dealer has finally admitted its a problem other than the height sensor - cue new air spring, air valve and something else tomorrow... will let you know if it works! |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
| dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851
My 08 TDV8 had a recall yesterday for the sensors, there was nothing wrong with the car but they were doing them al on my year.
| A12DY B Member Since: 21 May 2008 Location: WEST MIDS Posts: 335
mine is just being done now under warrenty as my air suspension was playing up |
| 4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955
So far my suspension has had, 1 compressor, 4 ride height sensors(recall) switch, pipework and now a new ride height control module on order. (And a partridge in a pear tree............ |
edit : the whole air spring needed replacing in the end, but did solve the problem |
| All times are GMT |
