Home > Technical > KNOCKING NOISE COMING FROM FRONT END
Page 8 of 8 <12345678
kedz
United Kingdom 2009 Range Rover Sport TDV6 HSE Alaska White
has anybody had this problem with an 09 plate one???????????
Post #221915 Fri Apr 10 2009 3:59am
dazsear
My 08 HST TDV8 went in the dealers today to sort out the knock and the seat movement and they cured the knock by removing some front mounted body shock absorbers.....no idea what they do but something to do with the dynamic something or other...lol
Would love to know what they do, not sure I like the idea of them being removed if they were fitted to the new car.
The knock has certainly gone but don't I want the handling to be affected in any negative way!
Any comments please.
Daz Thumbs Up 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #225907 Mon May 18 2009 6:46pm
Bobby
dazsear wrote:
.. they cured the knock by removing some front mounted body shock absorbers.....no idea what they do but something to do with the dynamic something or other...lol
I have mentioned here before that one of the solutions recommended by LR is to check the condition of the body frame shock absorbers, two infront and two at the back. They are to be changed if worn. However, for vehicles with Dynamic Response, then the worn front absorbers should be removed altogether. No need for them! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #225937 Mon May 18 2009 11:23pm
dazsear
But what do these front body frame shock absorbers actually do? (other than knock...lol)
I know LR suggest its ok to remove the front ones but not the back ones.
Daz 2017 4.4 Autobiography FFRR - love this car
Post #225940 Tue May 19 2009 4:27am
Bobby
Daz
absorb shocks?? Shocked
Seriously though, I think these additional shocks were weak and in conflict with the dynamic response features, particularly in the front. That is why LR recommends to remove the ones on vehicles with dynamic response. Malaysia Boleh!
Post #225941 Tue May 19 2009 5:16am
Another SW
The dampers you are talking about are to damp oscillations between the chassis and the body: Because the body is attached to the chassis by just 8 large bolts with big rubber bushes, there is the possibility of the body continuing to resonate after the chassis has settled, so small 'dampers' were fitted (RRS only) between body and chassis frame - for added luxury and comfort - compared to the more functionally focused D3.
I guess with DR they are not as important, as the DR system is designed to eliminate larger movements of the chassis at source... Question
However, I would have thought it would be better to fix them properly and stop them knocking rather than remove them Whistle
That's a bit like removing a trim panel because it's rattling and leaving a big hole and exposed wires and bolts instead Rolling Eyes
Post #225957 Tue May 19 2009 8:24am
Charlie Crocker
The dampers don't knock, they transmit the knock from the chassis to the body. The body amounts are elastomeric components for isolation the dampers short these mounts and therefore are a noise transmission path, thats why they take them off.
Post #243674 Wed Nov 25 2009 10:58am
Steven2011
Netherlands 2007 Range Rover Sport TDV8 HST Buckingham Blue
plum wrote:
Hello willem54, de officiële reactie van Landrover in mijn galerij.
Ik heb ook een RRS TDV8 2007 gekocht bij de dealer met garantie, maar ook hier krijgen ze het bonkende geluid niet weg.
is er nu een update voor of is dit gewoon een drama van een auto? Ik reed hier voor goede X5 maar heb wel enorm veel spijt van de RRS.
Post #308911 Sun Aug 07 2011 4:06pm
mees
Netherlands 2006 Range Rover Sport TDV6 HSE Java Black
Mine starts to knock only after driving more than 400-500 km. On normal days it's very quiet. The knock is there when slowly accelerating from standstill and also when slowly stopping. for example when you are driving in traffic jam. on high(er) speeds it's not noticable anymore. I cannot find something on this forum. Must be temperature related as the car is doing this only on very long journeys. Is coming from the front end. Any ideas?
Post #309305 Wed Aug 10 2011 3:24pm
