![]() | Home > Technical > How bad are the contis in rain? |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
I didnt find an issue with them in the wet tbh. Make sure your tyre pressures are correct. WINNER - 2008 Best All New Photograph
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Thanks mate...
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
Mine are worn a bit more than 50% with the sides scrubbed right down.
Thanks Paulo... You at least proved that I am not paranoid |
jambo Member Since: 31 Aug 2008 Location: Stoke on Trent Posts: 59 ![]() ![]() ![]() |
I've got goodyears on and find them excellent in all conditions - never had an issue in the wet (even in heavy rain) and i must confess to driving "passionately" |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
I really hated the Conti's (good for nothing IMHO and likely to leave you like a beached whale on any slightly slippy offroad surface). The Pirelli Scorpions seem to be doing a pretty good job so far (albeit with a rather weak sidewall !). RRS TDv8 HSE Rimini
Thanks guys for your input... |
Guys, is it safe to change my fronts for Pirelli's leaving Conti's on the back? 2022 P440e AB |
RRS11 Member Since: 20 Apr 2009 Location: Seoul Posts: 45 ![]() ![]() ![]() |
I'vr got Goodyear Wrangler F1 as well and I heard it does good job in rain. But is it ok in snow? Tread pattern doesn't look like it's for 4 seasons even though Goodyear web site says it's all-season tire. 09 TDV6 HSE, Stornoway Grey/Black, Sat. DMB/Navi, 2GB memory, Rear view camera, 12 CD/MP3/DVD changer, 35% Lumar tinting, Custom exhaust tips |
I'm very happy with my PIRELLI PZEROs and PA, yes you can just change the fronts to Pirelli and retain the Contis at the back. |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Well...Bobby, first post I'm going to have to disagree with you firmly on this guidance. It's always a bad idea to mix tires as suggested above, this will make the back end of the vehicle behave differently than the front due to different tread patterns, and all of the other characteristics of the tires. You are after all driving a reasonably pricey SUV, why would you shirk on spending a few extra hundred quid/dollars/euros on getting the right set of tires. Any tire shop that would even recommend such a thing is doing you a disservice. ![]() Cairns Blue HSE 180k Miles of Adventure |
No worries on the disagreement! After all its for the benefit of the forum in general and how else are we going to learn something new?! |
Good info, PJPRO01, but personally I agree with what Bobby has been told - as long as you maintain the same type tyres across axles I was never led to believe there was any problem. There's also the practical aspect. Many cars wear the tyres on the driving wheels before the other two need replacing. I'd probably say that the large majority of folks don't replace all four if they don't need to, especially if they're paying for them themselves |
