| RRSPORT.CO.UK | ||
|  | Home > Technical > How bad are the contis in rain? |
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704      | I didnt find an issue with them in the wet tbh. Make sure your tyre pressures are correct. WINNER - 2008 Best All New Photograph
|  Fri May 15 2009 11:47am |
| C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136      | Thanks mate...
|  Fri May 15 2009 11:53am |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    | Mine are worn a bit more than 50% with the sides scrubbed right down.
|  Fri May 15 2009 2:45pm |
| C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136      | Thanks Paulo... You at least proved that I am not paranoid   | ||
|  Fri May 15 2009 4:12pm |
| jambo Member Since: 31 Aug 2008 Location: Stoke on Trent Posts: 59      | I've got goodyears on and find them excellent in all conditions - never had an issue in the wet (even in heavy rain) and i must confess to driving "passionately"  | ||
|  Sun May 17 2009 8:53pm |
| Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939      | I really hated the Conti's (good for nothing IMHO and likely to leave you like a beached whale on any slightly slippy offroad surface).  The Pirelli Scorpions seem to be doing a pretty good job so far (albeit with a rather weak sidewall !). RRS TDv8 HSE Rimini
|  Sun May 17 2009 9:08pm |
| C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136      | Thanks guys for your input...   | ||
|  Sun May 17 2009 9:18pm |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    | Guys, is it safe to change my fronts for Pirelli's leaving Conti's on the back? 2022 P440e AB | ||
|  Sun May 17 2009 9:25pm |
| RRS11 Member Since: 20 Apr 2009 Location: Seoul Posts: 45      |
 I'vr got Goodyear Wrangler F1 as well and I heard it does good job in rain. But is it ok in snow? Tread pattern doesn't look like it's for 4 seasons even though Goodyear web site says it's all-season tire. 09 TDV6 HSE, Stornoway Grey/Black, Sat. DMB/Navi, 2GB memory, Rear view camera, 12 CD/MP3/DVD changer, 35% Lumar tinting, Custom exhaust tips | ||
|  Sun May 17 2009 9:32pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | I'm very happy with my PIRELLI PZEROs and PA, yes you can just change the fronts to Pirelli and retain the Contis at the back.   | ||
|  Sun May 17 2009 11:15pm |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355      |
 Well...Bobby, first post I'm going to have to disagree with you firmly on this guidance. It's always a bad idea to mix tires as suggested above, this will make the back end of the vehicle behave differently than the front due to different tread patterns, and all of the other characteristics of the tires. You are after all driving a reasonably pricey SUV, why would you shirk on spending a few extra hundred quid/dollars/euros on getting the right set of tires. Any tire shop that would even recommend such a thing is doing you a disservice.  PJPR 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS | ||
|  Mon May 18 2009 12:24am |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | No worries on the disagreement!  After all its for the benefit of the forum in general and how else are we going to learn something new?!   | ||
|  Mon May 18 2009 1:33am |
|  Mon May 18 2009 1:46am |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Good info, PJPRO01, but personally I agree with what Bobby has been told - as long as you maintain the same type tyres across axles I was never led to believe there was any problem. There's also the practical aspect. Many cars wear the tyres on the driving wheels before the other two need replacing. I'd probably say that the large majority of folks don't replace all four if they don't need to, especially if they're paying for them themselves   | ||
|  Mon May 18 2009 7:10am |
| Posting Rules
 Will have to get them changed soon than...
 only issue i've found with them is they tend to wear slightly more unevenly than the conti's, had the alignment checked, balancing checked and pressures checked regularly but it just seems to be one of those quirks !
