![]() | Home > General > 2 Stroke oil group buy interest |
I'm sure Forum Supporter OpieOils would be only too happy to supply... |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
I hope opie oils can help us...
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
I'm currently buying off the shelf from Wilkinsons at £1.99 per litre. This is FB rated, which is perfectly satisfactory as long as the car is not fitted with a DPF filter in the exhaust system. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Jo,
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
@ BigMart A st |
Hi Coko
Mart, really impressive. I am well interested. But how about its effect on the DPF? |
Coko,
Thanks Mart, read all the posts through.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
i am sure Yamaha-Fan would answer the query's if you posted them on the freel2 thread, if you want his opinion on anything. |
AndrewHG2 Member Since: 05 Sep 2008 Location: Harrogate Posts: 114 ![]() |
I have been buying a 1 litre bottle from B&Q for about £5 rated FASO FD, ever since reading the thread |
Andrew,
Yep that`s the one. |
BigMart, Sorry, yes I am buying the same 600ml bottles, not 1 litre as I wrote previously. Therefore I would be happy to join a group purchase for anything cheaper, especially at £1 per litre. According to Yamaha-Fan, there is no benefit in purchasing grades higher than FB if a DPF filter is not fitted. DPF equipped cars require a minimum grade of FC. For the benefit of the doubters, my indicated average fuel consumption for my TDV8 since 1st January is 28.4 MPG - mostly local driving. Prior to using 2 stroke additive I struggled to achieve an indicated average of 25 MPG. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
