Home > Technical > LARINI EXHAUST for the TDV8
Page 2 of 3 <123>
BigMart
Hi Chaps,
when I was at JP exhausts having my system fitted I was chatting to a chap who had a bmw 330d in for a complete system.
He owned a speed shop specilaising in bmw diesel tuning.
ANYWAY....
his system (own design) had no silencers because it had a dpf.
I thought it would be a bit lairy but he started it up , quite deep without sounding like a racing saxo!!
when revving it came alive sounding beefy but no reasonance or undignified beahaviour.
He was very happy with the system 'cos it was cheaper to delete all silencers.
Maybe JP will do a custom system with no silencers??
I know they were requesting TDV8 owners to help them to make the patterns for a TDV8 system but I havent seen any posts since.
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #180889 Fri Aug 01 2008 9:44am
That's interesting. I suppose it's obvious when you think about it, but I didn't think the DPF would have that much of a muffling effect.
Post #180897 Fri Aug 01 2008 10:08am
it seems they also have varying effects on power - this is only anecdotal, however when the pdf was introduced on the Touareg (3.0 V6 tdi) owners who'd previously driven the 2.5tdi or pre-DPF 3.0V6 tdi indicated that the power was down
Post #180901 Fri Aug 01 2008 10:13am
I suppose that makes sense too.... the DPF must restrict the flow of the exhaust to some extent.
Post #180908 Fri Aug 01 2008 10:17am
Ed Winchester
Belgium 2008 Range Rover Sport TDV8 HST Alaska White
Removing the final muffler is not bad idea actually, worth trying anyway. Thumbs Up
I'll post a soundclip on the Tube when the job is done. 2005 Range Rover Sport TDV6 HSE Java/Ebony(Gone)
2008 Range Rover Sport TDV8,Alaska/Alpaca,Stormers,JE Exhaust
Post #180918 Fri Aug 01 2008 11:21am
gigv8
Italy 2008 Range Rover Sport TDV8 HSE Java Black
I'm just back from an exhaust workshop where I discussed my point with the mechanic.
He told me that my idea could work, but to be advised that mufflers don't make much sound differences in diesel engines opposed to petrol counterparts.
But he also told me that it would be his first time on a diesel v8 so he really doesn't really know what to expect by removing the muffler.He also told me that the two smallest silencers at the end of the exhaust don't change the sound at all!!
Post #180995 Fri Aug 01 2008 5:33pm
Josh
gigv8 wrote:
.........He also told me that the two smallest silencers at the end of the exhaust don't change the sound at all!!
He is correct on the diesel, don't know about petrol. They are purely to make it look good TDV6 - gone
TDV8 - gone
Post #181008 Fri Aug 01 2008 9:39pm
Bobby
Something to read...
http://www.rrsport.co.uk/gallery/albums/us...%20DPF.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #181081 Sun Aug 03 2008 3:35am
Josh
Wow Exclamation Sounds expensive if it goes wrong. Thanks Bobby Thumbs Up
So it also reduces noise at low speed.
Well what with that and the new glass it might be silent in the cabin.....apart from the odd characteristic noise Whistle TDV6 - gone
TDV8 - gone
Post #181088 Sun Aug 03 2008 10:30am
Ed Winchester
Had a look underneath my car and apart from the 2 cats and the DPF there are no silencers in my system.
It seems that the only way to do this is by removing the DPF,replacing it with the '07 silencer and replace the software with pre DPF software so the sensors won't go apesh*t.
Does anyone know if the DPF and the non DPF silence are interchangeable?
One way or another, the DPF has to go.
Cheers,
Michael 2005 Range Rover Sport TDV6 HSE Java/Ebony(Gone)
Post #181132 Sun Aug 03 2008 6:11pm
Bobby
Michael, there are silencers in your system.
I hope this can help you...
http://www.rrsport.co.uk/gallery/albums/us...xhaust.pdf Malaysia Boleh!
Post #181161 Mon Aug 04 2008 12:47am
gigv8
Michael,
I had already thought to Your solution and it would be ok ,but there is a problem:
the sofware of the car performs some "minor" cleaning cycles without advicing You (You can hear them when the exhaust sound become a little bit deeper), even if You should find the way to trick the two pressure sensors of the DPF.
I was thinking about reinstalling the old pre-DPF software but Land Rover technicians told me that It would make malfuction other parts of our DPF equipped car.
I think we are stuck with DPF at the moment.
Post #181165 Mon Aug 04 2008 8:00am
So now we know! Thanks Bobby Thumbs Up
Post #181166 Mon Aug 04 2008 8:16am
Josh
Well done Bobby Thumbs Up TDV6 - gone
TDV8 - gone
Post #181196 Mon Aug 04 2008 10:03am
Ed Winchester
Thanks Bobby.Had a look underneath my car again in the workshop(replacement of leaking manifold for second time)
The JE system is connected to the DPF and runs al the way to the rear without any slincers in between,so there is no silencer no.8 as shown in the technical drawing. 2005 Range Rover Sport TDV6 HSE Java/Ebony(Gone)
Post #181503 Wed Aug 06 2008 11:03am
Page 2 of 3 <123>
