Home > Technical > LARINI EXHAUST for the TDV8
Page 1 of 3 123>
gigv8
Italy 2008 Range Rover Sport TDV8 HSE Java Black
Hello to everybody,
has anyone the Larini system fitted in the TDV8 with DPF ?
Does it sounds good anyway ?
Will it require some modifications?
Thank You in advance,
Giovanni
Post #179929 Fri Jul 25 2008 5:14pm
Josh
Hi,
I've got it fitted to a TDV8 and I also had it on a TDV6. Pics are in my gallery. Not sure what you mean by DPF Question
Sounds very good Thumbs Up
No modification to the lower valance required. Fits in perfectly and looks great as well Thumbs Up TDV6 - gone
TDV8 - gone
Post #180070 Sat Jul 26 2008 6:34pm
DPF = Diesel Particle Filter ??
Post #180071 Sat Jul 26 2008 6:38pm
gigv8
Yes , DPF stands for Diesel Particle Filter
Post #180096 Sun Jul 27 2008 10:00am
Josh
In that case the exhaust is fitted well behind the CATS, assuming the DPF is forward of the CAT it should have no effect Question
Because any modification forward of the CAT will definately invalidate your warranty.
Also has added benefit that the black stuff still exits downwards Thumbs Up
Not sure if my RRS has the DPF or not Question Where is the DPF in relation to the CAT Question TDV6 - gone
TDV8 - gone
Post #180106 Sun Jul 27 2008 11:27am
gigv8
Josh,
starting from the engine You have the two exhaust manifolds then two CAT units(one for each side),follows the DPF unit then a big muffler and at last two smaller mufflers one for each side just before the tail pipes.
Giovanni
Post #180118 Sun Jul 27 2008 1:34pm
Bobby
Here you go..
http://www.rrsport.co.uk/gallery/albums/us...onents.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #180143 Sun Jul 27 2008 11:18pm
Bobby wrote:
Here you go..
Nice one Bobby Thumbs Up RRS TDV6 Gone but still around
Post #180147 Mon Jul 28 2008 12:19am
The DPF has only recently been introduced I believe... 08 onwards if I remember (it's Mon morning and haven't had time to warm up my memory yet!)
Post #180156 Mon Jul 28 2008 8:44am
Josh
Thanks chaps.........well in that case looking at the diagram I don't really see any reason why a Larini exhaust would make any difference.
After all it's only a bit of stainless steel pipe with two modified SS back boxes. The old exhaust pipes are cut a short distance before the two back boxes and in it goes. It's not a performance enhancer......just looks really good and sounds a lot better (imho).........
Unless any one thinks I've got it wrong. I'm sure Larini would provide the exact answer. TDV6 - gone
TDV8 - gone
Post #180169 Mon Jul 28 2008 9:35am
Bobby
Yes, you're right shmoogle.
On vehicles from 2008MY the Diesel Particulate Filter (DPF) is available as an option.
The non-DPF exhaust system is also available. Malaysia Boleh!
Post #180307 Mon Jul 28 2008 3:10pm
Ed Winchester
Belgium 2008 Range Rover Sport TDV8 HST Alaska White
Salve Giovanni,
I have a Larini/JE system on my '08 car.
Like I mentioned in a previous post,the DPF has muted the V8 burble substantially and the Larini exhaust does't make it a whole lot different,looks a lot better though IMO.
If I were you I would order one without the rear pipes facing downward; the DPF absorbs most of the diesel soot anyway and it won't appear like you just slid a couple of €50 Halfords tips over the original exhaust tips.
Saluti,
Michael 2005 Range Rover Sport TDV6 HSE Java/Ebony(Gone)
2008 Range Rover Sport TDV8,Alaska/Alpaca,Stormers,JE Exhaust
Post #180482 Tue Jul 29 2008 3:19pm
gigv8
Hello Michael,
thank you so much for the good advice, I'm not going to spend over eur 1000 if it doesn't change too much the "voice " of the v8!
I bought the car knowing not too much about the DPF , if I had known about that I would have ordered the car without the filter!!
Did You cut the pipes that connect the DPF to the muffler in order to mount the Larini exhaust?
Have You got a sound file of Your DPF/Larini exhaust?
Giovanni
Post #180484 Tue Jul 29 2008 3:37pm
Ed Winchester
I had the larini system fitted by my landrover dealer before i took delivery of the car,all I know is that it took them a couple of hours to get the system fitted.
The first time I started the car I was hugely disappointed by the muted exhaust note,the salesguy told me it was due to the DPF and they would not be able to remove it .
No specialist in my surroundings is willing to fettle with the DPF,so until someone is up to the job I guess I'm stuck with it.
I haven't got a soundfile at the moment, but I'll put someting together this weekend. 2005 Range Rover Sport TDV6 HSE Java/Ebony(Gone)
Post #180500 Tue Jul 29 2008 10:20pm
gigv8
I was thinking about this:
since the cars equipped with the DPF Evil or Very Mad have actually two big filters , the DPF itself acts substantially as a " sound filter" too and the muffler, what about removing the silencer after the DPF ?
It should sound like You had just one muffler!! Smile Smile
Post #180882 Fri Aug 01 2008 8:41am
Page 1 of 3 123>
