| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Chipping the TDV8 (was Steering control buttons) |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      |
 This is absloutly correct m8 ,this is why when im asked EVEN THO i sell tuning and remapping, I give the truth about it because simply by using the dealer tool it can be traced using the tool correctly. Here is a few examples , and a simple ones at that. 1st way , measure boost presure, if its not standard its tuned. 1nd way , log injector duration , if its not standard its tuned. 3rd way , measure requested fuel in Mg's , if its not standard its tuned. ALL OF THESE SIMPLE TESTS CAN BE DONE WITH THE MAIN DEALER TOOL. The list goes on re the tests that can be made. Regarding the BDM , this is in my opinion the fastest way to void your warranty you may as well put it in the bin as soon as its done. Please see picture , i hope you understand.
 PS i chalange any tuner to prove different about traceability/invisibility   | ||||
|  Fri Dec 14 2007 10:27pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Just to add , when the ecu is powerd on the bench it will also give many intermittant faults codes, this is because the ecu is powerd and its not connected to the rest of its components like , temp sensors etc etc
|  Sat Dec 15 2007 7:41am |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551      |
 All of this makes sense BUT then I go and read this on your own website: "The performance remap or serial download we have produced for this Ford powered Landrover defender 2 , 2.4 common rail diesel engine is undetectable to the main dealer tools." How come? Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. | ||
|  Sat Dec 15 2007 10:18am |
| ginger Member Since: 03 Nov 2007 Location: Home Posts: 25  | Well spotted
|  Sat Dec 15 2007 1:51pm |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087    | Ok, How about my situation then!
|  Sat Dec 15 2007 4:29pm |
| ginger Member Since: 03 Nov 2007 Location: Home Posts: 25  | I think'll you find that the dealer will have breached LR's terms of sale and they (LR) WILL NOT have to honour the warranty.
|  Sat Dec 15 2007 7:20pm |
 YUP you read correct and its not a mistake either. I have the dealer IDS tool and have made extensive tests with it while developing the tuning for the new defender. Its logging functions on the new defender are somewhat limited to say the least. In the tuning of the new defender there is NO boost alterd to gain its power  "so it cant be moniterd with the IDS" It leaves no fault codes with the tuning method i use , andeven if it did i would errase after tuning. And function of logging the injector duration is not present in the IDS for the new defender either , so all i say on my site is correct at the time of print. Regards pete | ||
|  Sun Dec 16 2007 7:41pm |
| lummygee Member Since: 14 Dec 2007 Location: Bedford Posts: 2    | I been into to see the service manager at our LR dealer in Bedford they comfirm to me any comunications via the obd ports is logged on to part of the ecu which shows up in a counter showing how many times the ecu has beed accessed.
|  Mon Dec 17 2007 11:05pm |
| ginger Member Since: 03 Nov 2007 Location: Home Posts: 25  | BDM system sounds interesting but how do you hide the fact that the ecu has to be opened??  | ||
|  Tue Dec 18 2007 8:34am |
 I agree with you , you cant hide it, the installer can be carefull as he opens the ecu. But this still dont hide the fact that its had its seal broken. Only some tools add a flash marker on only some cars (mainley vag) by OBD tuning, i have many many tools for reading and writing many ecus and the BDM does as its been said NOT add a marker in most cases BUT you still need to open the ecu. Ive got a TDV8 to do this morning, ill make some screen shots of the dealer diag tool if i have time. Last edited by bellautos on Tue Dec 18 2007 5:26pm. Edited 1 time in total | ||
|  Tue Dec 18 2007 8:44am |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | @lummygee
|  Tue Dec 18 2007 5:23pm |
| Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980    | MMMM this is getting tricky now, I just feel now that LR are aware of the amount of ECU mods, whether done by LR dealers or not, they will be looking for these changes in a bid not to honour any repair claims. Think i will leave mine just the way she is..........for now at least. Speed Limits! not where I live!
|  Fri Dec 21 2007 8:59pm |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | Steve I'm with you - once my warranty expires I might get a remap. 2005 Zambezi TDV6 - Gone but not forgotten
|  Fri Dec 21 2007 9:08pm |
| ginger Member Since: 03 Nov 2007 Location: Home Posts: 25  | Apparently LR have had several major component failure warranty claims and the common link to all these cars is that they were all 'chipped'  | ||
|  Sat Dec 22 2007 8:40am |
| Posting Rules
