Home > Technical > EGR Valve! Can you help??
guyrayner
United Kingdom 2008 Range Rover Sport TDV6 S Santorini Black
Hello,
Just bought an 08 RRSport 2.7TDV6 S with 29000 miles on. The engine management light is on and when the diagnostics was plugged in it said that there was a fault with both EGR valves.
Can these be cleaned and put back on or do you have to replace them?
Also, if you have to replace them does anyone know if you can get aftermarket ones or are they main dealer part only?
Any help or advice greatly received.
Thanks!
Guy
Post #292376 Tue Mar 15 2011 5:07pm
have you got any LR warranty left on it?
If so..get it to the dealer asap Thumbs Up
As far as I can remember, the EGR's are genuine LR only and I've not heard of people refurbing them..just straight swap old for new... not cheap.. RRS gone
Post #292377 Tue Mar 15 2011 5:10pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Hi Guy, I had the same problem with my 2007 Tdv6 S, just one EGR, tried to clean it but it didn't work, part has to come from Landrover circa £130.00 plus VAT, plus fitting. You can't blank 2007 onwards as the engine light won't go out. Rolling Eyes
Post #292378 Tue Mar 15 2011 5:11pm
guyrayner
Just out of warranty unfortunately and it also missed a service in 2009 so they wont do the work for nothing.
Do you know what an EGR valve actually does?
Do you know how much they charged for fitting?
Thanks!
Guy
Post #292382 Tue Mar 15 2011 5:18pm
1JBS
Exhaust Gas Recirculation valve to reduce emissions! Fitting for me was £45.00 plus Vat for one valve...
Post #292383 Tue Mar 15 2011 5:20pm
They always go wrong - some people swear on using premium grade diesel to help prevent failure but there's no conclusive proof. 2005 Zambezi TDV6 - Gone but not forgotten
Post #292384 Tue Mar 15 2011 5:23pm
Yes it's just a butterfly valve with a motor that draws exhaust air into the intake when you take your foot off the gas... then closes again when you throttle up and need cool clean air..
They can stick open..meaning warm exhaust gasses being used all the time..resulting in poor performance.. RRS gone
Post #292385 Tue Mar 15 2011 5:24pm
That sounds very cheap... Use this garage!
I've heard £600+ for a main dealer to do one valve... RRS gone
Post #292386 Tue Mar 15 2011 5:26pm
guyrayner
Ive noticed that the car does seem to be a bit more 'Rattley' than the others ive had. Could this be why?
Can using the vehicle whilst having this fault lead to other problems or am i ok to drive around with it on for a while?
Post #292392 Tue Mar 15 2011 7:06pm
pawmaro
United Kingdom 2006 Range Rover Sport TDV6 S Bonatti Grey
EGr
my sport had transmission fault, suspension on deck park brake fault and wouldnt rev or drive.
All this was down to 1 egr valve. Steve Hill Landrover sorted it
Post #292393 Tue Mar 15 2011 7:12pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
was discussing some typical faults with a land rover mechanic today and he tells me the new 2010 onwards 3 litre RRS has the intercooler fitted after the EGR valve line as opposed to having the intercooler fitted before the EGR valve on the pre 2010 cars.
the effect?
as the return gas is no longer cooled before it enters the EGR valve, it does not build up as much gunk in the valve.
all in all the pre-2010 EGR layout seems to be a pretty F*#Ked up design.
Post #292422 Tue Mar 15 2011 10:34pm
guyrayner
Thanks for all the help lads. Looks like im going to have to bite the bullet and get some bought.
I have a pal who has 2 new RR Sport EGR valves which were bought for a 2006 model. Does anyone know if they would be ok to go on my 2008 S model? Im guessing that they should be the same?
Also if these are fitted by a non LR dealer will the engine management light automatically go out or will i have to take it to them to tknock it off?
Guy
Post #292432 Tue Mar 15 2011 11:27pm
1JBS
They may not be the right ones as 2007 onwards was a different emissions standard, regarding the light it will more than likely have to be reset by someone with a specialist computer. Your best bet would be a good independant Land Rover garage.
Post #292434 Tue Mar 15 2011 11:46pm
Dave1888
Scotland 2007 Range Rover Sport TDV6 SE Rimini Red
I've just had the AA out to check my engine check light, the codes are P0489 and P0490 egr low and egr high. I take it the egr valve will have to be replaced Sad 2007 RRS V6 2.7 SE
2006 Tiger Cat E1
2007 Vectra Sad
Post #292478 Wed Mar 16 2011 2:07pm
1JBS
I'm afraid so, it is such common problem, bad design! Sad
Post #292484 Wed Mar 16 2011 3:26pm
