Home > Technical > EGR Valve! Can you help?? |
have you got any LR warranty left on it?
Tue Mar 15 2011 5:10pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Hi Guy, I had the same problem with my 2007 Tdv6 S, just one EGR, tried to clean it but it didn't work, part has to come from Landrover circa £130.00 plus VAT, plus fitting. You can't blank 2007 onwards as the engine light won't go out. |
Tue Mar 15 2011 5:11pm |
guyrayner Member Since: 15 Mar 2011 Location: Whitley Bay Posts: 4 |
Just out of warranty unfortunately and it also missed a service in 2009 so they wont do the work for nothing.
Tue Mar 15 2011 5:18pm |
Exhaust Gas Recirculation valve to reduce emissions! Fitting for me was £45.00 plus Vat for one valve... |
Tue Mar 15 2011 5:20pm |
They always go wrong - some people swear on using premium grade diesel to help prevent failure but there's no conclusive proof. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Mar 15 2011 5:23pm |
Yes it's just a butterfly valve with a motor that draws exhaust air into the intake when you take your foot off the gas... then closes again when you throttle up and need cool clean air..
Tue Mar 15 2011 5:24pm |
That sounds very cheap... Use this garage! I've heard £600+ for a main dealer to do one valve... RRS gone Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Tue Mar 15 2011 5:26pm |
Ive noticed that the car does seem to be a bit more 'Rattley' than the others ive had. Could this be why?
Tue Mar 15 2011 7:06pm |
pawmaro Member Since: 16 Oct 2010 Location: Bristol Posts: 10 |
my sport had transmission fault, suspension on deck park brake fault and wouldnt rev or drive.
Tue Mar 15 2011 7:12pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
was discussing some typical faults with a land rover mechanic today and he tells me the new 2010 onwards 3 litre RRS has the intercooler fitted after the EGR valve line as opposed to having the intercooler fitted before the EGR valve on the pre 2010 cars.
Tue Mar 15 2011 10:34pm |
Thanks for all the help lads. Looks like im going to have to bite the bullet and get some bought.
Tue Mar 15 2011 11:27pm |
They may not be the right ones as 2007 onwards was a different emissions standard, regarding the light it will more than likely have to be reset by someone with a specialist computer. Your best bet would be a good independant Land Rover garage. |
Tue Mar 15 2011 11:46pm |
Dave1888 Member Since: 09 Jan 2010 Location: Livi Posts: 14 |
I've just had the AA out to check my engine check light, the codes are P0489 and P0490 egr low and egr high. I take it the egr valve will have to be replaced 2007 RRS V6 2.7 SE
Wed Mar 16 2011 2:07pm |
I'm afraid so, it is such common problem, bad design! |
Wed Mar 16 2011 3:26pm |
